Question about Haier Washing Machines
Hi i am washing machine expert. sometimes i thought about to find RPM of any electric motor weather its small or large because its my passion to collect information about my business... so please give me the solution of problem. email. arslan_00@msn.com
I was talk about that... how to check motor RPM? so the solution is....
Calculating Motor Speed:
A squirrel cage induction motor is a constant speed device. It cannot operate for any length of time at speeds below those shown on the nameplate without danger of burning out.
To Calculate the speed of a induction motor, apply this formula:
Srpm = 120 x F
P
Srpm = synchronous revolutions per minute.
120 = constant
F = supply frequency (in cycles/sec)
P = number of motor winding poles
Example: What is the synchronous of a motor having 4 poles connected to a 60 hz power supply?
Srpm = 120 x F
P
Srpm = 120 x 60
Srpm = 7200
Srpm = 1800 rpm
Posted on Jun 24, 2009
How to get the clothes to spin dry in Color wash mode?
Program the machine for white wash and turn down temperature and duration manually, and tune up the sentrifuge program to maximum RPM.
It helps to use a machine with large drum and minimum 1600 RPM. Large diameter of the drum is more efficient than a small diameter drum at the same RPM.
Sep 08, 2014 | Electrolux EW1000i Front Load Washer
In the spin cycle at high rpm's the drum is making a load noise. Is it he drum belt? If so how can I replace it? I can't find a cutsheet on the parts list.
Hi there
Before you startreplacing partsin the machine, observe weather the washing is evenly distributed in the drum when it is working.
If the washing is not evenly distributed, there is a lot of noise and the drum does not go its rounds evenly.
good luck
kolbrun
Mar 10, 2012 | GE Energy Star WCVH6260F Front Load Washer
I have the error EH0 in my washing machine ZWG6165
hi error eho is aproblem with the electric supply being outside the voltage acceptable 230volt range or not a clean supply( small generators dont give a consistant supply to satisfy the electronics). recent bad weather can affect the supply in rural areas you may find the finer weather will irradicate the problem.
Feb 09, 2011 | Washing Machines
We keep getting an overload motor message and the washer won't activate. What is the most likley cause?
Sometimes just running a bulky load at a high spin speed will do that, but if that is not the only time it happens, then replace the Hall sensor. It is a small part cliped onto the stationary coils of the motor. Unplug machine. Remove back cover. Remove large bolt in center of motor rotor. Pull rotor off. Remove metric bolts from stationary coils to remove coils. Unplug electric connectors from coils and Hall sensor. Unclip Hall sensor from coils. Reverse process to install new sensor. (note: sensor itself has 5, 7, or 10 year warranty, depending on when the unit was manufactured, but is not that expensive anyway) Other much more unlikely causes could be a bad motor stator, rotor, wire connecting motor to control board, plug in of wire at motor or board, board itself, or the shaft of the "spider" loose from the rest of the spider. (three arms of spider attach to the back of the inner wash drum)
Jan 01, 2011 | LG WM-2277HW Front Load Washer
Maytag Neptune FAV6800AW Code LL Machine displays code LL and will not complete the spin cycle when there is something in the basket. Will complete if empty. Thinking the issue is the tub displacement...
Hey HopelessR,
The LL error code For the FAV6800AW is one of those errors that I feel is not documented very well. The only explanations I see is Large Load detected, “” The washer cannot spin because the load is to large”” OK what the heck is the trigger input to the Control Board to issue this error code to the Console Display????
I believe it’s Motor RPM not reached. I would try the Quick Spin Test on page 14 of the Service Manual and see if your machine will spin up to 850 RPM with an empty wash basket. Do you run up to 850 RPM “85.”?
I then reran the test with two large bath towels that were soaked, had to lay them in the wash basket to balance as best I could. I wanted to rerun the test with some load. The wash basket spun up thru all ranges to 850 RPM and completed with 3 beeps. Just wondering what RPM range you can complete too.
I have to additional commenst, this board has message limits for guys like me.
Oct 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 23, 2009 | Washing Machines
My series 90 washing machine stops midway through the rinse cycle
Hi, faulty timer motor or timer, knob you turn for different cycles (programs) , it's called timer, that timer usually run by small motor, and sometimes burnt out, could be electronic too, remove top back panel, look at timer, you'll see small motor, attached by two small screws, remove motor, place ohm tester lead, and check for continuity. if motor is burnt out, replace it, if your timer is electronic, you will have to replace complete timer, good luck.
Aug 08, 2009 | Kenmore 22422 Top Load Washer
Wiring diagram for electric motor Sole made in Hungary Model 205850 AC EL CL F 110V 16K RPM 110 volt"
The more I look at this motor the more I think that it is a stepping motor and not an AC motor... I could be wrong, but checking the windings and seeing the small Tach Motor on the rear leads me to believe that this is not a ac motor, but a stepping motor and is triggered from the programmer for rpm
Apr 30, 2009 | Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Washing Machines Logo
93 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
