Question about Sigma Sport Cycling
I use the 1609 on my bike. By accident, I hit a button that changed the settings. Not sure what the original settings should be. I need some help walking through and making sure they are correct. Wheel size I think is key
    New Friend:
  • 3 Answers
Have you checked the manual? Pages 24 & 25 should be able to help you.
If you don't have a copy its available on the Sigma Sport site. http://www.sigmasport.com/en_media/produkte/bikecomputer/topline_2009/topline_wired/bc1609/allgemein/visuals/ba.pdf
Posted on Apr 15, 2015
5 Suggested Answers
SOURCE: What must be setting on wheel size if my bike
get a tape measure and measure the out side circunfrance of the wheel. This is you number. OR put a white dob of paint on the tyre and roll it in a strainght line until the dob of paint makes a 2nd mark, (on a path way etc) measure the distance. this will be the same as the first option. Generally its required in mm.
Posted on Oct 26, 2009
  • 547 Answers
SOURCE: how do I calculate wheel size for my bike. 25 inch...
There's a size chart on page 15 of the manual that has great instructions for measuring and entering the wheel size.
You can get the manual from Sigma's website at this link.
Method "B" is the most accurate way -- make a chalk mark on the tire and stand the bike up next to a wall with the chalk mark at the bottom.
Have a friend make a chalk mark on the ground at that point.
WITH YOUR FULL WEIGHT ON THE BIKE, move forward for one rotation of the wheel -- until the chalk mark is on the bottom again. Do this as straight-line as you can.
Have your friend make another mark on the ground at this point, and measure the line between the two points on the ground.
This is the wheel circumference, and if you do this with normal tire inflation and with your full weight on the bike, it's the most accurate way to calibrate your cyclocomputer.
If this helps, please be sure to hit the "thumbs up" for me.
If not, of if you have questions, use "add comment" to post back here, and I'll do my best to get you going.
Posted on May 22, 2010
dunnbiker
  • 8546 Answers
SOURCE: i need the settings
All you need to do is measure the diameter and do the math or for precision, roll-out one revolution on the ground and measure it in millimeters and divide by 1.61 (or multiply times .621).
(Consult chart or figure yourself by measuring from the top of the tire to the ground in inches.) Measurement X 25.4 x 3.14 / 1.61 = ws ( / is divided by)
http://www.thisoldtractor.com/gtbender/mg_manuals/sigma_sport_bc1200.pdf
There's a chart in the link below. I believe Columns E and F apply.
http://www.sheldonbrown.com/cyclecomputer-calibration.html#ccc
Posted on Jan 18, 2011
dunnbiker
  • 8546 Answers
SOURCE: I'm trying to set up the correct wheel size for my
The manual explains how to measure your wheel exactly and set it into the computer...
http://www.sigmasport.com/en/service_center/produkt_support/bikecomputer/?flash=1&typ=bikecomputer
Page 28 and 30.
Posted on Feb 08, 2011
Battery replacement for bike odometer
-Nothing will last. Keep charging when it's low.
Good luck
Mai
Jan 22, 2018 | Sigma BC 1609 STS Wireless Bike Computer
How to change the language on the eclipse
press the up button about 7 times. Then go down 5 times. Hit the middle button. go down 3 times. It should say english
Jun 12, 2013 | Mach Speed Trio Eclipse 180 G2
My vtx1800c motorcycle may or may not turn on when I hit the ingintion
...... and when you put the kill switch into the run position, did things return to normal?
Mar 07, 2013 | Motorcycles
Hi my bike was on my stand i started and accidently put the bike into first gear and it sytaled right away..and now its not turning over wen i try and start it, it makes a clicking sound but wont turn...
The bike must be in neutral when the kickstand is down or it will shut down. Its a safety feature.
Put the bike in neutral and it should fire right up.
If you can't get it out of gear, sit on the bike, put the kickstand up, pull the clutch in turn the key on and hit the start button, and it should fire right up.Make sure on/off button is on too.
If you tried that and it still clicks, check battery voltage, a low battery makes the solenoid click.
Make sure you have a clean battery terminals and tight terminals.
Check battery voltage. Most auto parts places will load test them for free.
If battery is good and it is in neutral and it still clicks, then the starter solenoid is bad.
replace the solenoid. And your bike should fire right up
Nov 29, 2010 | 2003 Honda CBR 954 RR Fireblade
Curser is set to move by the arrow keys. how di I get it to go back so I can move it through my keypad
most probably you accidently hit the scroll lock button.
press the scroll lock button again.
-----Original Message-----
I must have hit a control function. Now instead of
moving up/down/left/right
in
individual cells, I am moving the whole page. Any Ideas?
Thanks
Ike
Oct 04, 2010 | Acer NSK8458AN Keyboard
I need to change the atomic clock from military time to standard 12-hour format...can't find original manual...have owned the Radio Shack clock for 5 years.
Hit the set button until the number 24 shows up instead of the time. Hit the "+" button once, and it will switch from 24-hour to 12-hour display. Hit the set button to cycle through the rest of the settings.
Jun 22, 2010 | SkyScan 86709 Atomic Wall Clock
Changing language settings
hit your screen to get to where you see preferences... click on the preference button, then click on the voice button, it is an icon with lips... you can change the original settings for language and voice from perferences.
Apr 17, 2009 | Tomtom ONE GPS Receiver
GENX Softwear needed
بدي تعريف سكانر من نوع genx600ومش عارف أجيبة
Apr 20, 2008 | Office Equipment & Supplies
Cycling Logo
238 people viewed this question
Top Sigma Sport Cycling Experts
kirkjw
Level 1 Expert
Tom Chichester
Are you a Sigma Sport Cycling Expert? Answer questions, earn points and help others
