Jvc LCD 34 inch model number LT-32N330A. I got a half screen other half vertical coloured lines on left hand side
5 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: sharp lc26sh20u 26"flat panel has vertical lines on left side,What coulb be problem?
This line would either indicate a horizontal problem cropping up or a power supply problem
I would suggest getting a service tech to look at it to determine where your problem is coming from but most likely it will be the power supply /deflection board that is the problem but I can't know for sure, it will have to be checked.
A lot of sets have had damages after a long hot summer a/c flipping off and on and current demand being peeked from the utilities storms or quick power loss off and on can cause problems like this to occur
Please let me know if you have any other questions, thanks
Posted on May 14, 2008
  • 586 Answers
SOURCE: two inch wide vertical band spreads across half of screen
The problem is in vertical section and the faulty components are :
1- Capacitor
2- Transistor
most probably the poped capacitor must be the reason, check and replace the faulty components.
Thanks for using fixya.
Posted on Jul 01, 2009
  • 68 Answers
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Posted on Nov 28, 2009
  • 8457 Answers
SOURCE: left side (50%)of lcd screen has multi coloured
Ur backlight video board is the prob.Must change.try this website for the part.Shopjimmy.com
Posted on Dec 09, 2009
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Bravia KDL46w5500. Why does it display vertical lines all over the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 30, 2015 | Sony Televison & Video
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
I have a LT-46244 and there are two vertical black
No format burn-in if thats what you mean, tv needs to serviced. good luck Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
