Question about Samsung Washing Machines
Replace belt in samsung c835 - Samsung Washing Machines
Installing samsung clx6220 image unit
See page 103 of http://downloadcenter.samsung.com/content/UM/201112/20111205134621713/EN/English.pdf. It looks like the clx6220 uses a transfer belt to transfer all the different toner powders to the paper.
see
http://www.genuinetonercartridges.com.au/genuine-samsung-clp-620nd-clp-670nd-clx-6220fx-clx-6250fx-page-image-unit-transfer-belt.html
The transfer belt unit is refered to also as the image unit !
Also each toner cartridge contains the OPC drum and is replaced when you replace a toner cartridge by the look of it.
You need a transfer belt to transfer the image to the paper and this is why they call it an image unit.
I am guessing that the transfer belt needs replacement !
Sep 08, 2014 | Samsung CLX6220FX AllInOne Laser Printer
I need to know how to tighten the belt on a samsung dryer
the belt has a self adjusting idler pully you can not adjust this to make the belt any tighter. just make sure the belt is properly attached.or replace the belt as needed
Sep 12, 2010 | Samsung DV306LEW Electric Dryer
Replacing belt in samsung dryer I cant get the
This photo is from a Samsung DV409AEW, but I assume they are quite likely the same.
If they are the same route the belt per the photo below. It is counter-intuitive that the spring pulls the arm down, rather than to the left. Hopefully this will be your issue.
Hope this helps!
Feb 21, 2010 | Samsung Dryers
Replacement transfer belt on my Samsung CLX-2160 not recognised?
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Dec 12, 2009 | Samsung CLX2160 Multifunction Color Laser...
During a storm, i had the tv on & the picture went out on it when it thundered.
Sounds like an overlaod in the power supply. Check the cap at C835 and if possible use a cap-analyser on all of them in the PS circuit. Are there any signs of life when you press the power button?
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Philips Magnavox 27MS343S 27" TV
CLX-3160FN askes for replace TRansport belt, is it a
replace belt,take drum out slide transfer belt wich is located ontop of drum.see how it is connected,slides in/out.
Jun 24, 2009 | Samsung CLX 3160fn All-In-One Printer
Transfer belt error
Transfer belt error, this is cause by the OPC drum which connects the belt. Make sure the drum sit well with the belt else replaced the drum.
Jan 29, 2008 | Samsung CLX 3160fn All-In-One Printer
Clicking sound
I found the problem.
I've written up a small article on my website detailing the fix but in summary here:
Electrolytic Capacitors C826 and C835 go bad because of the heat stress applied by the audio amplifier right below them. Replacing those capacitors fixed my 150MP.
For more information see:
http://www.benjammin.net/www/pages/techtips/Samsung-150mp.html
Jul 06, 2007 | Samsung SyncMaster 150MP Monitor
Washing Machines Logo
32 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
