Question about Spark Plugs BR4HS Plug 10/BX #3322
What is the setting gap - Spark Plugs BR4HS Plug 10/BX #3322
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
What does it go on that is the question
Posted on Sep 06, 2014
What should the spark plug gap be set to?
the spec is .043", for both the V6, and the Inline 4. The theory behind enlarging gaps, is that a larger gap creates a larger spark, thus more effecient ignition. The problem is, your ignition system was designed for the .043" spark plug gap, not larger. Enlarging the gap puts a greater strain on your ignition system components, and it may not be strong enough to jump a larger gap. The result would be less efficient combustion, or a cylinder(s) that won't fire at all. Pull your plugs, and set them at .043". Check the distributor cap, rotor, wires, and your filters. Make sure the car is totally warmed up before the smog test. Good luck.
Jun 04, 2016 | 1990 Toyota Corolla
What is the spark plug gap
When replacing your spark plugs you need to set them at the spec set by your auto manufacturer. Gap means the distance between the electrode and the little metal hook looking pieve at the end of the plug. This is on the threaded side of the plug. There is a $2.99 gap tool that has most gap settings engraved, your vehicle will have the gap required on a label under the hood
Feb 25, 2015 | Cars & Trucks
1968 Ford Ranchero
Spark Plug Gap is .032 inch. Many have started using .035 as it is easier to set using most newer tools.
Point Gap is .016 inch. You may also set point gap by using a dwell meter if you have one. That setting would be 32 degrees.
Aug 01, 2014 | Lisle 67870 Spark Plug Gauge Gap
Spark Plug Gap for 1996 GMC Jimmy
They should be pre-gapped, but you should always check in case someone dropped the box.
The gap is .060
Jul 18, 2012 | 1996 GMC Jimmy
What is the spark plug gap setting for a Saab 9-5 (1998 2.0l model)
The spark plug gap setting for a Saab 9-5 (1998 2.0l model) is: 1,0 ... 1,1 mm.
Please do rate my response. Thanks!
Jan 06, 2011 | 1999 Saab 9-5
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
Whats the sparkplug gap set at its a 4 cyl 2003 alero
SPARK PLUG GAP SETTING IS 2.4L ENGINE GAP SETTING IS 0.050 FOR THE 2.2L ENGINE SPARK PLUG GAP IS 0.060
Dec 08, 2010 | 2003 Oldsmobile Alero
I need the Gap settings
the sparkplugs are shipped with the propper gap setting *DO NOT CHANGE IT"
if its been altered, place a penny in the gap, and thats the space it should be gapped.
Mar 04, 2010 | 1994 Mazda MX-3
My 2004 ford ranger 3.0 6cyl has an incorrect gap setting
Depending on the mileage, the excessive gap may be due to wear. It also may be from the plugs not being properly gapped when they were previously installed. I would recommend installing a new set of plugs, and setting the gap to the factory specs.
Nov 18, 2009 | 2004 Ford Ranger
What gap should i set my new spark plug before i
the plug gap should aleady be set from manufaturer, but incase you think its been dropped or something, the gap should be at 1.1mm
Jun 30, 2009 | 2005 Gilera Runner VX 125
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
13 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
steve morris
steve morris
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
