Question about Raypak RP2100 DIGITAL POOL HEATER R265
How to activate the pilot light? - Raypak RP2100 DIGITAL POOL HEATER R265
    Problem Solver:
  • 19 Answers
Pilot lights but goes out when knob is released
It can take near a minute 60 seconds to get the pilot light to heat the thermocouple to activate the pilot gas control valve.
You may need to be a little patient. Make sure that the thermocouple has not been disturbed from its home location. You should see the pilot flame just touching the sensor.
Nov 24, 2015 | Heating & Cooling
Still can't find where you light the pilot light for the hot water heater on a self igniting factory installed heater on a 1997 Pace Arrow.
Generally, if a RV water heater is self igniting, then it is not designed to be lit manually. If you remove the outside vent cover door, then the unit can be observed. The self igniter should be visible at a point of where the pilot light is located. The problem with trying to light the water heater manually is that the circuit that activates the igniter also turns on the gas at the same time. If the igniter is not getting power, then most likely the valve to turn on the gas is not getting power either. If the problem is that the igniter itself has failed, then it may be possible, but unlikely, that with someone inside activating the turn on switch and a flame being applied to the pilot light area, at the same time, the pilot may light.
Oct 04, 2015 | Water Water Heaters
How do i light the pilot light
Dryers do not have pilot light, you either have a spark or a hot surface igniter. Both are electrically activated.
Feb 10, 2015 | Kenmore 80 Series Heating Element -...
Pilot goes out
The pilot may no be strong enough to keep the thermocouple active . check to see that the pilot is engulfing the thermocoupler completely.
You may have to adjust the pilot for a stronger flame or you may have to clean the pilot orifice if it is dirty. Hope this helps.
Dec 30, 2013 | Blodgett 1060 SINGLE Gas Pizza Deck Oven...
It wont heat
never heard of having a pilot light as well an ignitor, the two don't go together. If your have a pilot light that is on the unit is getting gas. If there is pilot light there is usually a knob to switch between pilot light, off, and active on. maybe set to pilot light only.
Nov 09, 2013 | Amana ALG331RAW Gas Dryer
Pilot light stays lit but blower motor will not kick on
The blower won't turn on, until the burner is lit and builds up enough temperature to activate the blower.
If you haven't already, turn the control knob from Pilot to ON. that will activate the burner.
Feb 16, 2011 | Coleman Heating & Cooling
The pilot light on our tankless water heater will not stay on.
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out
Sep 20, 2010 | Bosch Water Heaters
Dryer runs fine but does not heat
Check that the pilot light is lit and flame kicks on when dryer is activated. If no flame, then check gas valve. If only pilot remains lit but does not increase when dryer is activated, then you could have a bad coupler or sensor or circuit problem which would have to be tested with a voltmeter and/or test light.
Nov 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Raypak RP2100 DIGITAL POOL HEATER R265 Logo
107 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
