Question about Canon BubbleJet i560 InkJet Printer
Why give me info on i560 mine is an i965?
My printer is a Canon i965 not560
SOURCE:
mediatecar
  • 60 Answers
SOURCE: I965 print problem
if you used the right cartridges (here you can see them http://www.mediatec.ro/mt_main.php?consumabile-cartuse-toner-inkjet&st=1&marca=Canon&model=i%20965&tip=inkjet - first are compatibles and second the genuine Canin ones) the printer should start. Did the printer worked fine until previous cartriges runned out?
Posted on Feb 15, 2008
SOURCE: changing cartridges on Canon i560 printer
you can download your user guide or instruction book here
Posted on Apr 05, 2008
Tirzo
  • 94 Answers
SOURCE: Canon i965 flashing amber light
Your printer experienced a PrinterPlease try the following to resolved that issue:
1. Resetting the Printer
By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur.
Follow these steps to reset the printer:
Turn the printer off with the Power button (if available).
Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
Turn the printer back on.
2. Reseat Print head
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If those steps above are exhausted and issue still present printer may require service.
Posted on Jun 11, 2008
  • 2715 Answers
SOURCE: Canon i965 printer; no printing
Try the print head cleaner routine. Directions in your product manual:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=9388
Posted on Jan 17, 2009
SOURCE: Error message 5200 on Canon printer i965
Sent the printer for repair to the local Canon Service Centre.
Posted on Apr 17, 2009
Canon i965
Did you check your manual for the error codes? Check with Canon?
May 12, 2014 | Canon BubleJet i965 InkJet Printer
Canon i965. light tones leaning to magenta. printer 6 years old
Because of the way they're designed, older Canon printers can sometimes get dirty print heads which can cause some ink colors not to come out properly or at all. This can cause light printing or a tendency to a certain color, like what you're describing.
The best thing to do would be to go into the Printer Settings (by opening Control Panel -> Printers and Faxes) and right-click on the i965 to select 'Properties'.
Somewhere in that menu will be an option to run a Print Head Cleaning. Find that and allow it to run, and then print a test page to see if the colors have gotten back toward normal.
If it's still printing strangely, you might want to try to find a new print head (check www.canon.com to see if they still support the i965 model). If you can't find a replacement head for the i965, it might be time to buy a new printer, since it will probably cost more to have yours looked at and repaired than it would to simply replace it. Sad, but true!
Hope this is helpful!
May 08, 2011 | Canon BubleJet i965 InkJet Printer
I can not reinstall my cannon i560 and i don't
Go on www.canon.com and they will give you all the information you need.
Jul 27, 2010 | Canon Office Equipment & Supplies
Canon I965 waste tank almost full - how do I clean/empty or clear
You will have to get it replaced by a Canon agent.
Phone Canon for nearest agent
Just had mine done cost £50.00 +VAT
The codes on line to reset counters will not solve the problem and eventualy ink will leak from the printer.
Feb 24, 2010 | Canon BubleJet i965 InkJet Printer
Apr 14, 2009 | Canon Office Equipment & Supplies
Canon pixma mp190 driver for windows me
On January 18, 2007 Canon released new Windowme drivers for the following printers and multifunctions:
S100, S100SP, S200, S200SP, i320, i250, i255, i350, i355, S300, S330, i70, i450, i470D, i455, i475D, i80, S500, S520, S530D, i550, i560, S600, S6300, S630, S750, i850,  i6100, i6500, i860, i865, BJC-8200, S800, S900, S9000,  S820, S820D, i950, S830D, i9100, i990, i960, i965, i900D, i905D, i9900, i9950, MP360 Series, MP370 Series, MP390 Series, MP700, MP730, iP1000, iP1500, iP2000, iP3000, iP4000, iP4000R, MP750, MP760, MP780, iP5000, iP6000D, iP8500, DS700, iP90, DS810, iP1200, iP1600,  iP2200, iP6210D, iP6220D, MP150, MP170, MP450, MP500,  MP830, iP4200, iP5200, iP5200R, iP6600D
I have MP780 (print, scan, copy, and fax).  The released file mp780vst620en.exe does not install the multifunction MP780 correctly.
Does anyone know work around, please?
Thx.
Feb 15, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon i965
www.canon.com has those by model and operating system.
Aug 20, 2008 | Canon BubleJet i965 InkJet Printer
I965 print problem
Feb 14, 2008 | Canon BubleJet i965 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
Clive
Clive
old marine
old marine
