Question about Garden
Lawnflite 603 engine cuts out
Engine works fine but when engaging the cutters lever safety switch cuts engine. Safety switch replaced, if safety switch by-passed cutters will engage but when safety switch re-engaged, engine will cut. Not a safety switch problem but maybe relay further up the loom? Need this machine working as summer is just round the corner(hopefully)
  • 83 Answers
SOURCE: Starter will not engage. All safety switches are
Here is the manual. It includes a troubleshooting chart and the location of the fuses. Give it a shot and if it does not work out contact me again.
http://manuals.deere.com/cceomview/OMM142612_D7/Output/Index.html#25348
Posted on Mar 30, 2009
  • 16 Answers
SOURCE: my mtd pinto mower engine cuts out when cutters engage - why?
it sounds as if your carb is dirty remove bowl on carb i"ll bet it's it's dirty if so you will need to remove the carb and clean it
Posted on May 30, 2009
SOURCE: husqvarna ct 135 mower,when attempting to engage
Hi Janet,
its the warning button on the grass collector. If the button is not pressed in fully, the machine thinks that the grass collector is off, and therefore stops the engine. I had the same problem. If you take the grass collector off, you will see the button on the top left side of the back of the mower. It is covered by a strip of black plastic that slots over it.
To fix the problem my first solution was to tape a washer onto the plastic strip, thereby ensuring that the button is pressed fully in when the grass collector is on. When I got tired of the washer continually falling out, I used a screw to jam the button in. You should be aware though, that with the second method you will be able to engage the cutters with the grass box removed. Potentially a small child (with long arms) could put his/her arm down the shute and chop fingers off etc. I have no kids, and thereby feel safe.
Posted on Jul 16, 2009
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
  • 54 Answers
SOURCE: Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Posted on Apr 28, 2010
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
John deere
Is there a safety switch anywhere you overlooked?
Sep 01, 2014 | Garden
I have a castelgarden ride on lawnmower when i engage the cutting blades the engine cuts out why is this?
sounds like you need to test the safety switches with a ohm meter start with the one on the seat then check the one on the clutch/brake pedal the look at the one in the reverse position
Jun 12, 2012 | Garden
Hi, I have a westwood t1500 with B & S engine which starts fine also runs fine with cutter disengaged,when cutter engaged it sends out clouds of white smoke and idles to a halt. Any ideas Regards ...
Sounds like the cutter is not turning free causing the engine to drag down and stop, I do not think the B&S engine is the problem. I have rebuilt dozens of these engines and most of the problems with a Briggs engine was dirt in the gas or carburetor that needed needle valve cleaned . If the cutters turn free, check for a bad or out of adjustment safety kill switch that engages and stops the engine as the cutters are engaged.
Sep 06, 2011 | Garden
I have a 92 fzr 600 when i engage my clutch amd shift into first it dies like the clutch isnt engaged. i checked the clutch cable and it seems to be working fine
With the engine not running can you select 1st gear pull in the clutch lever and push the bike with no difficulty, if you cant, it may be the clutch plates have become stuck together, this can occure from standing for long periods, if you can push the bike it may be the neutrol safety switch, or the side stand safety switch have become faulty, and cutting the bike out as a precaution
Jul 25, 2011 | 1992 Yamaha FZR 600
My husqvana lawn tractor starts well and the engine runs but when I release the brake or apply the cutter it cuts out. Why?
Most likely the seat safety switch or associated wiring is the problem. It's designed to cut the engine if you release the brake or engage the blades unless it detects your weight in the seat. Tip up the seat and make sure the safety switch under it has not come loose, and that the wire connections are on tight. If that all looks OK, take the switch off and put a piece of tape over it the plunger to keep it in the 'activated' position and see if the mower works that way. If that fixed it, you should replace the safety switch. They are just a few dollars. Hope this helps - if so, please rate my answer.
Jul 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My 603 lawnflite ran over a man hole cover and
Should be just behind the dash
May 29, 2010 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
