Question about Cell Phones
How do I adjust the ringing volume on a Pabx Digital Telecom System 32KD-06G?
2 Suggested Answers
SOURCE: Alcatel Office View 32KD(SA) manual required
http://rapidshare.com/files/138838661/Manual_AlcatelOfficeView.rar
Posted on Nov 23, 2009
How to turn down ring volume
I assume you don't have the manual, which would supply the answer. Usually there are buttons just under the digital screen that are the entrance to functions and programs. Look for "menu", and keep pushing until the digital shows ring volume. Should indicate arrows up & down to adjust. Or look along the side of the unit for manual adjuster.
Aug 17, 2012 | Panasonic KX T7235 Corded Phone
How do you adjust the number of rings?
Each ring is 6 seconds. Phone your phone provider and ask them to set the rings to 36 seconds for 6 rings
Feb 29, 2012 | Aastra Telecom Powertouch/Vista 390 Corded...
Phone won't ring and I have checked the ringer switch
If there is a volume switch on your phone then while it is ringing (call the number from a cell or something) and as it is supposed to be ringing. Just hit the right arrow to turrn it up. Hope this helps. P.s. it has to be ringing when you are turning it up
Sep 20, 2011 | Aastra Telecom 9116 Corded Phone
Hi Gooday! Im a Panasonic pabx technician...i had a problem with our current project pabx system the CO card or trunkCard always hung and all line always busy...whst is the posible problem of my...
Two possibilities. The C.O. is not sending a disconnect or the timing needs to be set. It's a C.O. trunk time you adjust first and if that doesn't work, call the telco. We have hardware to simulate disconnect supervision if the phone company (or PBX extension like a Panasonic) can't provide it. We have to use them on elevator extensions.
Carl
May 24, 2011 | Panasonic Lands Phones
HELLO EVRY BODY, We have a cordless phone gigaset 4015 with gigaset confort handset 4000 the only problem is when we receive a call , we can hear only the first ring and the handset still blinking...
First of all you have to change the Dialing mode, DTMF or Pulse, according PABX type, ask to technicians!
Second step is to set up the Flash Time from 80 to 800 ms, again in dependency of your PABX Operating Instructions. Cheers and good Luck.
Oct 09, 2017 | Siemens Gigaset 4015 Cordless Phone
Volume too loud on handset
The phone at the back of the base has an adjuster check if its there if not while having a communication try using the minus sign to reduce the volume.
Jan 13, 2010 | British Telecom Synergy 2110 Cordless...
My phone's(htc touch diamond)ringing volume is too low... i can barely her it ring in my pocket
there are 2 buttons on the left hand side of the phone. press the top button to increas the volume...
there are 2 volumes you can adjust, the system volume and the ring volume. you may have to touch the "Ring" tab on the top right hand side of the screen to adjust the ring volume
Jul 08, 2009 | HTC Touch Diamond Smartphone
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
CAT5e
The max distance that Cat5e or Cat6 can be run is 90 meters or 295 feet. As cnavarro stated, signal repeaters would be best utilized in your situation up to 590 feet otherwise fiberoptics are the next and more expensive route. You should also divide the run equally with the repeater as it would not be effective with an offset balance.
Sep 14, 2008 | Cat5e 100 Foot Shielded STP 350mhz Network...
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
