Question about Sony VAIO VGN-NR120E/S Notebook
Sony vgn-nr120e wifi not working - wireless lan switch "on" no light. Been using for an hour and suddenly its not working.
  • 255 Answers
Reinstall your wireless drivers..
this problem is due to not driver correctly installed
Posted on Jun 23, 2009
My vaio smart connect has been deactivated ,i think....everytime i try to swich on the bluetooth or lan it says'turn the WIRELESS switch on VAIO to on'
they could be a switch on your laptop that you have to turn on. look for it check on the sides or front.
when is on you should find a light on with a wifi icon.
otherwise look for a wifi simbol on your keyboard usually in a different color meaning you have to press it with the FN key pressed
May 14, 2011 | Sony VAIO VGN-AR630E Notebook
I have Sony VGN-NR120E. When i turn on my computer, nothing appears on the screen and the power sign is only on (battery, turbo and lan sign are off). Its like frozen, and i dont think the fan is working...
1. Unplug your computer and remove the battery.
2. Press the power button several times.
3. Reattach the battery, plug in the computer, and press the power button.
4. If the problem persists, look closely at the screen. If you can make out faint, dim images, the backlighting components must be replaced or repaired. If not, it is likely another issue with the physical hardware of the machine such as the screen or the motherboard.
Mar 05, 2011 | Sony VAIO VGN-NR120E/S Notebook
I can not find wireless switch... wireless is turned off....... please help me to wireless turn on..... my modal no:- VGN-NR220E help me.......................................... my email id:- osho...
The Wireless LAN switch on your laptop is located to the right of the SD card slot and power indicator lights on the front of the laptop. If this does not work, the entire Users Manual can be accessed by going to:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGNNR220ES
Hope I helped!
Jan 17, 2011 | Sony VAIO VGN-NR220E/S Notebook PC
I want to get all my sony vaio vgn-s590b driver program because i cant get wifi signal n lan for the internet'
Unfortunately, the Wireless card in the VAIO model VGN-S580B does not support n standard. The integrated Intel PRO/Wireless 2200BG Network Connection Driver supports IEEE 802.11b and IEEE 802.11g standards. It is require to use an external Wireless card to use the n standard.
However, here is the link to download all the drivers for your computer model:
http://esupport.sony.com/CA/perl/swu-list.pl?mdl=VGNS580B&LOC=3
Thanks
Jan 03, 2011 | Sony VAIO VGN-S580B (VGNS580B03) PC...
VAIO VGN-NS190J/S 15.4-Inch Notebook PC (2.0GHz Intel Core 2 Duo Processor T5800, 4GB RAM, 250G: The wifi light won't turn on when I put the switch...
They issue is due to the corrupted SmartWi Connection Utility Software in the Computer.
You will need to re-install the Wireless LAN Driver, Updates, and the SmartWi Connection Utilities in the Computer to fix the issue with the Wireless.
You can download the Wireless LAN Driver, Updates and the SmartWi Connection Utility from Sony Support Site.
Below are the links.
Wireless LAN Driver
Wireless LAN Driver Update 1
Wireless LAN Driver Update 2
  1. Please download and save each file on the Desktop.
  2. After that double click on the Original Wireless LAN Driver to begin the installation.
  3. Please follow the onscreen instructions to complete the installation.
  4. After that, restart the Computer for the settings to take the effect.
  5. After restarting the Computer, please install the Updates.
  6. Make sure that you restart the Computer after each installation.
  7. Then, please re-install the "SmartWi Connection Utility in the Computer.
You can download the SmartWi Connection Utility from here.
  1. Download and install the SmartWi Connection Utility in the Computer.
  2. after the installation, please turn ON the Wireless Adapter using the SmartWi Connection Utility.
  3. Please click "Start", "All Programs" and SmartWi Connection Utility to open the Program and turn ON the Wireless Adapter.
  4. After that, please re-configure the Wireless Network connection in the Computer.
  5. This should fix the issue with the Wireless Network connection.
May 18, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Sony vgn-nr120e stops working
Uninstall unnecessary softwares from add/remove programs. Did you noticed that cpu fan is working? If not then clean the cpu exhaust system with blower and also check the cpu fan function in BIOS. When using laptop always use flat surface to place it, mattress or sofa create problem with cooling and exhaust system of the cpu fan.
Hope this will help you.
Regards;
Hasan
Dec 30, 2009 | Sony VAIO VGN-NR120E/S Notebook
Sony VAIO VGN-NR120E/S PC Notebook not powering up
ur boot files are being corrupted either there is a trojen or a virus that's preventing the Win from working.
do this...when u switch on the machine press F8 function key and try to load in Safe Mode. if u can do that then get Tuneup Utility from my website (download page) www.sureshayyar.110mb.com
install and run the cleanup process...1n click maint in that does a good job...use all the tools in that and get ur machine to working....
else u need to boot from a Win CD try do a repair of ur OS....
else let me know...we go to plan B
Dec 29, 2009 | Sony VAIO VGN-NR120E/S Notebook
Lan switch not turning on
Go into your BIOS (by hitting a button like Del or F2 when your computer starts up) and see if your LAN is disabled in one of the menus there.
Mar 19, 2009 | Sony VAIO VGN-NR120E/S Notebook
Wireless switch not working, is there another way?
Hi, My Name is Henry. I am one of the technicians here.
You need to try re-installing the drivers for the wireless adaptor.
If that does not work then I think you will have to get a repair person to check it.
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
Sony VAIO VGN-NR120E/S Notebook Logo
1,075 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
