Question about HP S2331 23-inch Diagonal Lcd Monitor - Black
S2331 monitor comes on for 1 second and goes blank
The Monitor comes on for 1 second and then goes to black screen, How cna i fis this?
SOURCE: Monitor going black
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Posted on Oct 17, 2006
hockeyguyJC
  • 133 Answers
SOURCE: Blank screen, but has power
It is most likely a backlight that has burnt out or something else of the sort. You will want to call HP Support and explain to them of your troubles.
Posted on Aug 17, 2008
PaulRepair
  • 66 Answers
SOURCE: After hooking up this monitor,the 1702 goes
Hi Don,
it sounds like your monitor's Capacitors have gone bad. This is very common. It is repairable, but the caps have to be removed and new ones resoldered on.
If you have soldering skills, not too tough of a job. If not, a shop will usually charge around $100 or so. You will have to weigh the cost vs a new monitor on this one.
Here is some more info for you on the Capacitor plague, that is quite common on monitors now.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 09, 2009
romsky79
  • 822 Answers
SOURCE: Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
Posted on May 31, 2009
  • 788 Answers
SOURCE: blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Posted on Sep 03, 2009
Testimonial: "I am very happy that this guru was able to concisely evaluate the problem from the information provided. "
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Screen comes on then goes blank after 1 second
Is the power led button still on? if yes, it means the picture board is malfunctioning.
The picture board on your monitor is bad, since it goes black after a second, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 29, 2010 | Dell E153FP 15" LCD Monitor
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
My monitor screen goes black
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
May 16, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
HP S2331 23-inch Diagonal Lcd Monitor - Black Logo
201 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
