Question about John Deere Garden
John deere CYL HEAD BOLTS torque
WHAT IS THE TORQUE VALUE OF THE 5.9L 6 CYL ENGINE CYLINDER HEAD BOLTS (3140 TRACTOR)
  • 98 Answers
SOURCE: how to rebuilt the cylinder head of daihatsu charade 3 cylinder engine
Which motor?
Posted on Sep 04, 2008
bunnydawg
  • 5158 Answers
SOURCE: 91 kx 250 torque values
Engine Top End:
Auto Decompressor Bolt 104 in·lb
Cylinder Head Cover Bolts 87 in·lb
Cylinder Head Bolts: M10 36 S
M6 104 in·lb S
the S in that means the specified pattern ... just like tightening car tire bolts... please note all that it its INCH lbs....
don't know why it says just 36 for the M10 bolts unless they left out inch lbs
Anything else let me know as i've got a manual for the 250 f... actually i've got a few different ones
Robert
Please take a moment to rate this solution as i've taken a few minutes to find the manual thanks
Posted on Jan 28, 2009
  • 25 Answers
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Posted on Mar 17, 2009
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
polarcycle
  • 1392 Answers
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Posted on Aug 16, 2009
What is the torque for the axle pivot bolt on a John Deere L 130 lawn tractor
the bolt is M12x80?
if so you have 2 options
if the bolt is strength 8.8: 93Nm
if the bolt is strentgh 10.9: 137Nm (most unlikely)
strength is shown on the top of the head of the bolt
Aug 13, 2017 | John Deere Garden
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
How to setup the timing on a 1941 john deere tractor and which cylinder is number 1.
The number one cylinder is the one closest to the front of the engine/tractor. When you look from one side across the top of the engine you will see that one of the cylinder heads is slightly forward of the other. The one that is most forward of the two is number one. This simple trick works on ALL multi-cylinder engines. Twin to W-18. The most forward cylinder head and the most forward cylinder on that head. If the engine is mounted backwards or sideways the front of the engine takes precedence.
Mar 24, 2016 | John Deere Garden
Compression in a 1966 john deere tractor its a 2020
is this a multi cylinder diesel farm tractor or what
remember that questions go global and you have to be specific in details as a jd unit 202 in your country may be a 1212 or what ever in another country
however moving on , if it has more than 2 cylinders , the problem can be a head gasket blown between adjacent cylinders , cracked head or valve problem ( burnt or incorrect valve adjustment)
same ideas apply to petrol engines as well
Dec 15, 2015 | John Deere Garden
What do i torque the head bolts at?
John deere is proprietary. That information is not public.
Sep 02, 2015 | John Deere 4020 Gas & Diesel Tractor...
How to access cylinder head on husqvarna rider?
?? Why do you need the head torque? Was this an overhaul? Consult the factory service manual. If not possible, torque setting depend on several factors, .. application, (cyl. head), engine mounts, etc.. this is mainly determined by bolt and nut size and relative to the application. There are charts that recommend toque values relative to bolt sizes. I can't tell you because I don't know what size the bolts are! Hope this helps!! Goolge it!
Aug 17, 2014 | Husqvarna Garden
What is the proper sequence for the head bolts on a deisel 3020
the head bolt torque is 130 +or- 5ftlbs and as far as sequence if not sure start in the middle of the head and work your way out alternating side to side and in an X. Step up to 130 by starting at 80-100-115-130.
Nov 09, 2013 | John Deere 3010,3020 Tractor Basic...
Head bolt sequence and torque values on a 1999 Chevy 3.1L engine
if the 8th number om your VIN is a "J" then this is the correct prossess 3.1LTorque sequence --------- ' 6 2 3 7 ' ' 5 1 4 8 ' --------- Step 1: torque in sequence to 37 Ft/Lbs Step 2: turn an additional 90 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.Always coat bolt threads with the proper sealant.
if the 8th number on your VIN is a "M" then this is the correct prossess 3.8LTorque sequence --------- ' 6 2 3 7 ' ' 5 1 4 8 ' --------- Step 1: torque in sequence to 37 Ft/Lbs Step 2: turn an additional 90 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.Always coat bolt threads with the proper sealant.
Oct 12, 2011 | 1999 Chevrolet Malibu
Hello, does anybody know the torque setting for the head bolts ona v-twin yanmar desiel engine fitted in a john deere 355. Cheers
I found the tech manual one lin but it can"t be opened since deere is updating it.I will see if we have the book"tm1974" at the dealership in the morning and get back to you.
Oct 28, 2009 | John Deere 4020 Gas & Diesel Tractor...
Garden Logo
42 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
