Question about Legrand Hardware & Accessories
Instructions for Legrand 03755 MicroRex qw31 Timer
03755 MicroRex QW31 Timer, Please can u help,I have no instructions on how to set it to auto mode,Thanks
  • 86 Answers
SOURCE: need instructions on how to set timer
Here's a link to Intermatic manuals on-line:
http://www.intermatic.com/Default.asp?action=cat&cid=91
Posted on Mar 01, 2009
shunt311
  • 34 Answers
SOURCE: Model #15119 GE plug in
Hi, here is the manual for your timer.
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
You need the adobe reader to view PDF file's if you dont have it here is the link.
http://get.adobe.com/reader/
Good luck (",)
Posted on Jan 07, 2011
SOURCE: I have a Hager (leGrand)
http://waterheatertimer.org/How-to-program-Hagar-timer.html
Posted on Apr 27, 2011
SOURCE: I misplaced my instructions for my timer and need
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
Posted on Sep 04, 2011
  • 246 Answers
SOURCE: operating instructions for a legrand timer on a night storage heater
http://www.legrand.us/passandseymour/timers/7-button-preset-digital-timer/rt1w.aspx is the link to follow for operating instructions...only thing I could find that was related...hope it helps!
Posted on Jun 10, 2012
How to set legrand timer switch 12 hours model # 037-55 microrex qw31
QW31 is 7-day analog timer, 230 Volt
http://waterheatertimer.org/How-to-set-timers.html
If there is a photocell override, then it will be wired into terminals U1 and 4, and will not be part of the timer setting
Gene
Water Heater Timers Save Money
Oct 15, 2014 | Legrand Ivory Universal Timer Controlled...
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Trying to set my malibu power pack and need directions
That's because you have the timer (dial) mode set to "auto" Turn the dial to "Timer" mode, then follow the directions in the manual. You will also have to set the clock to use the timer mode, again, read the manual.
Here is the instruction manual:
http://www.homedepot.com/catalog/pdfimages/d6/d607d4a8-39b7-4de0-aa94-3fbe86280636.pdf?cm_mmc=seo'altruik'202059606
If you are still having trouble, post back with specific questions, as the instructions are rather tedious.
Dec 08, 2011 | Malibu ML200RT - Low Voltage Power Pack...
My ge model 15117 heavy duty timer will not go off in the auto mode. I changed it from auto to off to turn my pump on and then went back to auto and now did not turn off when timer expired
I cannot repair defective timers, and there are complaints about this timer's MODE button.
Most people complain they can't get mode to set.
Avoid the MODE button after programming timer.
Reset the timer by pushing CLOCK PROG MODE buttons. Then re-program the timer per instructions, and then press CLOCK button to exit programming and timer is in Auto mode and ready to work.
No need to press MODE after programming timer.
Typically, this timer has limited 1 year warranty.
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15117
15117 is not heavy duty timer. Both outlets combined are rated 1000 watts incandescent and 1/4 HP. Check nameplate on your pump for HP rating.
For limited-lifetime-warranty timer, rated 1/3 HP, choose Intermatic HB800RCL 2-outlet timer.
Cost twice as much as GE 15117.
For 1HP outdoor pumps choose Intermatic P1121
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 08, 2011 | Sport & Outdoor - Others
I bought a Major Tech Mtd9 programmable timer but there are no instructions included, only features. I have no idea how to set the date and the timer. Say I want the light to switch on at 6PM and switch...
First press reset (use pen or paperclip). Press MOVE button until you get OFF at right bottom of screen, then press SELECT to select mode (to set time and date, to select on/off for the 2 timers or to select rundown timer. Use OK to move to different setting, eg. hour,minute, year,month day etc. Use SELECT to change up one digit at a time. Play around with buttons to change settings, for example to have timer on on a specific day of the week or everyday etc. When it is set, use move to change from OFF to AUTO, timer will then switch on and off at set times. Hope it helps
Jul 31, 2011 | Kitchen Appliances - Others
Set timer for the 7-day outdoor timer i.e. 5:00 pm on and 9:00 p.m. off Also set the clock ~ should it be left 'on' for the timer to work? Have lost the manual our programmer
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Dec 05, 2010 | Intermatic HB88RC - 7-Day Programmable...
Whirlpool Gas Dryer LGR7646JQ1 Auto Setting Does Not work
I am thinking the timer has gone bad, They tend to work in some spots, and not others , when they fail. If you can put the dryer in Auto mode, then nudge the timer until you hear the burner light, see if it continues from there. If it does, chances are pretty good it's the timer.
Jan 27, 2009 | Whirlpool LGR7646E Dryer
How do I use the self timer on my PowerShot A570 IS camera? Please help...
Press the Center Button
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
  • ISO speed (Auto, High ISO Auto, 80, 100, 200, 400, 800, 1600) - see below
  • White balance (Auto, daylight, cloudy, tungsten, fluorescent, fluorescent H, underwater, custom) - see below
  • Drive (Single-shot, continuous, 2 or 10 sec self-timer, custom self-timer)
  • My Colors (Off, vivid, neutral, sepia, black & white, custom color) - see below
  • Flash compensation (-2EV to +2EV in 1/3EV increments) + flash output (1/3, 2/3, full) - this last item is only available in manual mode
  • Metering mode (Evaluative, center-weighted, spot)
  • Compression (see chart later in review)
  • Resolution (see chart later in review)
The Third Option is Having Self Timer ..... Check
Oct 14, 2008 | Canon PowerShot A520 Digital Camera
Hardware & Accessories Logo
367 people viewed this question
Top Legrand Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Legrand Hardware and Accessory Expert? Answer questions, earn points and help others
