Question about Sub-Zero 601R
The door of fridge was left open now it's not turning on but the freezer still works
5 Suggested Answers
  • 1462 Answers
SOURCE: cannot open the bottom freezer door anymore; it seems stuck
sounds as though the defrost system has failed or the freezer defrost drain is blocked. take off the back panel of the freezer and see if excess ice build up. if so, defrost carefully with a hairdryer. at bottom is a drain. check if blocked with ice and if so melt off with hot water till water flows away freely. if i'm right, appliance will start to work. if fault re-occure then defrost system is at fault
Posted on May 06, 2007
  • 56 Answers
SOURCE: i left the freezer door open
You have too much frost in the unit evaporator unit and the evaporator fan is hitting the frost.. Press and hold the ice on/off key for 10 seconds to induce a manual defrost.
Posted on Dec 02, 2008
SOURCE: Door difficult to open
Simple fix! A small puddle of water near the fridge led me (indirectly) to this fix. Our model is a fridge only, no ice or water dispenser and nothing spilled inside. Upon closer inspection I found a narrow tray along the back wall above the crisper drawers with a drain hose leading under the unit. Apparently it's a condensate drain, a plugged one at that! I cleaned it out, yuk, and soon discovered it serves a dual purpose... as a vent to help relieve the pressure from the vacuum created immediately after closing the door. It has renewed our love affair with this fridge. Hoo Hoo!
Posted on Dec 18, 2008
walterkunesk
  • 683 Answers
SOURCE: Left the fridge door slightly open last night and
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
let me know if this works.
Posted on Feb 22, 2011
My ge profile pfs22sbsss model french door freezer drawer was left open overnight and now won't get cold. Any ideas?
THE FREEZER HAS FROZEN PAST THE POINT OF DEFROST;TURN FRIDGE OFF AND MANUALLY DEFROST ALL THE ICE IN THE FREEZER SECTION AND ALL AIRWAYS TO FRIDGE SECTION.
May 10, 2014 | Refrigerators
I have a dometic rv fridge, the freezer works not the fridge
you have to send the brand name and model number so i can help you.all that happens is the evapcoil in the freezer gets cold,the evap fan motor blows cold air from the freezer into the fridge side,depending on your model you could have a bad damper,this is a door that is in the fridge section,it opens and closes letting the air come in,try this,open the freezer door,if you don't hear the fan blowing you could have a bad fan motor,also touch your hand on the back inside wall of the freezer,if you have frost or like ice on the back wall you have a defrost problem,ice is biulding up on the coil and the fan can't blow the air over to the other side..if you need more help,do these tests and send the model number off of the machine and brand name,side by side or freezer on bottom,open the fridge door,look up on right hand side wall near ceiling or on ceiling,freezer on top look on left side in fridge section.
Jul 12, 2012 | Dometic Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
Swan fridge freezer-freezer dones,nt get down to temperature but fridge is working fine.if you turn up the thermostat the fridge acts like a freezer
There is a damper door that opens and closes when you move the thermostat. I would bet the door is functioning incorrectly. All the cooling of a refrig comes from the freezer and gets blown into the refrigerator compartment. If that damper door is open too far it will have constant freezer air blowing in....and if it's not open enough obviously the refrig will not get cool. Look at the upper left corner of your refrigerator, the center rear wall of the refrig or just feel around for a vent will cool air blowing out of it......Then take it apart and see if anything is broken.
Sep 09, 2009 | Refrigerators
Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Dec 17, 2008 | Whirlpool GB2SHDXP Bottom Freezer...
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
