Question about Garden
Where do i locate engine oil drain nut on mountfield hp454
2 Suggested Answers
SOURCE: How do I change the oil in a Mountfield Emperor
the drain plug is located under the mower. above the blades. just look for a freeze plug that you can fit a 3/8" ratchet into. Remove the plug, wait for the oil to drain, then replace the freeze plug. You might have to get a water hose and wash the under carriage out and get all the grass off before you'll be able to see it.
Posted on Sep 20, 2009
Testimonial: "Thanks so much for getign back to me. Mission is now accomplished less mess than turning the mower on its side which was looking like the only option!"
Oil replacement
Exactly below the engine near rear Tyre, to see this you have to bend the scooty fully. there is a small nut we can operate it with a spanner, that is for gear oil drain. at the center portion there is a big aluminium nut of about two inch diameter which can only be operated by key , that is for engine oil drain further detail you can contact me by kiransh999@gmail.com
Feb 25, 2014 | 2011 TVS Scooty Pep Plus
Where is the oil drain plug on a 2002 BMW 325i
It is located on the oil pan, please be advised the oil pan is also the casting that houses the front differential, and the engine oil drain is the hex nut furthest to the rear of of the pan . You will need a 17mm wrench to remove the hex nut . After you drain the oil, DO NOT over tighten the plug . The proper torque is 25 newton/meters or about 20 foot/pounds
Sep 12, 2012 | 2002 BMW 5 Series
How do you change the oil in a mountfield LS45 Lawnmower???
While I am not familiar with this brand, typically, in a four cycle lawn mower engine, there will be a oil drain plug in the bottom of the engine or on the lower part of the engine above the deck.
Thanks for your question @ FixYa.com
May 19, 2011 | Garden
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Where is the oil filter located?
i think it underneith the engine buddy the black or silver filter get back to me if im wrong
Sep 24, 2009 | 1997 Honda Hornet 250
I have a Mountfield HP474 lawnmower. We cannot locate the sump plug to drain the oil. Please could you advise. Many Thanks Gavin
According to the operators manual there is no sump plug, instead you "dump" the oil out using the oil fill.
Below is step by step instructions copied from the Operators manual:
Drain oil while the engine is warm being careful not to touch the hot engine nor drained oil
a) Place engine level
b) Clean around oil fill
c) Remove filler cap
d) Have a container ready to collect the oil
e) Tip the lawnmower on its left side so that the oil will drain from the oil fill
f) Place the lawnmower level and top up with new oil
g) Check the oil level on the dipstick
Oil should be at "MAX" mark
h) Close the filler cap and wipe off any spilled oil
NOTE: The oil capacity is about 0.6 liter
Sep 20, 2009 | Garden
How do I change the oil in a Mountfield Emperor Lawnmower? I can't see where to drain it.
How much oil does a mountfield omega lawnmower take
If it is a small horsepower engine 4, 5, 6 HP, it will take approximately 20 ounces. If it is a larger engine8, 9 ,10, 11, 12 and on up it will take from 40 to 48 ounces
Sep 13, 2009 | Garden
The engine oil filter is located just right of center if standing in front of the car. By removing the LARGE Black cap with the 36mm nut you will expose the filter element, make sure to do this before draining the oil from the drain plug in the pan. Otherwise the filter will still hold oil until loosened a bit. A typical oil change should go like this.
1. Engine Hot, not running, Loosen filter housing, don't remove yet.
2. Drain Oil, Replace plug.
3. Remove and Replace filter and O-Rings
4. Add oil.
May 08, 2009 | BMW 530 Cars & Trucks
How do l change oil and filter on focus estate 2000.
Well, you'll want to get under your car and locate the oil pan. It should look something like a metal box and you'll find it in the middle of the engine area. There will be a nut, probably 9/16th size, so you';ll need a wrench or socket. When this becomes loose enough, use your fingers to twist it off. Be warned! Once this nut is off oil will immediatly become rushing out. You'll probably want to have a bucket or something to catch the oil. Once the oil has drained, tighten the nut back onto the oilpan. The oil filter shouldn't be far from the oilpan, probably a little bit upwards, you'll should be able to see it from where you drained your oil, but you can also sometimes spot it when leaning over your engine. Be sure to wet the lip of your new oil filter with clean/new oil before replacing it!
Feb 25, 2009 | 2000 Ford Focus
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
