Question about Epson Stylus Color 1160 InkJet Printer
Not printing with new cartridge
Installed new black cartridge and still not printing after numerous nozzle checks and cleaning
  • 400 Answers
There is possibility that USB cable have got broked ... get it checked
Posted on Jun 23, 2009
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
Blurred printing new black cartridge installed - we still have blurred printing.
It is problem on cartridge setting may be it select color cartridge.or clean your black cartridge check nozzle print test.
Feb 12, 2010 | Canon PIXMA iP5300 InkJet Photo Printer
Will print only color. will not print black with a
First print a test page to make sure the printer's firmware is working correctly. See here. Check here to see that you have the most current driver installed for your OS.
Then use this article to set the print properties to print in grayscale using the black ink cartridge only, and test the printing.
If you get no output from the black cartridge, see this article or this article for help with cleaning and checking the cartridge contacts. Make sure the tape is removed from the cartridge nozzle. You may try running the auto clean utility a couple of times, but be aware that this consumes ink, and if you are not getting black printout, it's likely that the print nozzles are clogged with old ink. Sometimes even a new cartridge can be out of date, or have been stored incorrectly, and cause this.
I've read of cases where people were able to use a vacuum nozzle to clear clogged cartridge nozzles and get them operating again, but haven't tried this myself, and recommend if you do you attempt it in an environment where ink can be cleaned up. (See here for more on that.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 28, 2009 | HP DeskJet 5150 InkJet Printer
Canon i70 black cartridge issues
If you hold the resume button until the green light flashes twice, it will print out a nozzle check print. You need to see the black cross hatch pattern at the top of the page. If it's not there you will need a printhead, QY6-0046-000
around $40.00
Aug 03, 2009 | Office Equipment & Supplies
Stylus printing striped alternating shades of yellow and green of image
Possible printhead issue.
Please reseat the black cartridge. Let the printer charge like it normally does.
Print a nozzle check pattern. If you see gaps, missing lines or missing colors on the pattern, clean the printhead using the driver. 3 consecutive cleaning cycle is recommended. Compare the nozzle pattern over the last printout. If you see any improvement, you can clean the head numerous times until you get a perfect nozzle check pattern.
Apr 30, 2009 | Epson Stylus C86 InkJet Printer
Unable to clean Epson C88 Nozzle
In view of leke0513's lack of interest in this problem, I think we may say it has been "solved by poster".
Mar 25, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson cx9400 printer/scanner/fax
Follow these steps to print a nozzle check:
  1. Load letter-size paper in the sheet feeder.
  2. Press the cp_button_1.gif On button to turn on the Epson Stylus CX.
  3. Press the Setup button.
  4. Select Maintenance and press OK.
  5. Select Nozzle Check and press OK.
  7. Press the cp_button_6.gif Start button to print a nozzle check.
  8. Shown below are some examples of what the nozzle check may look like.
Mar 01, 2009 | Epson Stylus CX9400 Photo Printer
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
Black ink
Leanne83 and jzig - I presume your problems are solved by now. If not, please respond with a new comment.
Guest
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're SURE you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try up to 3 head clean/nozzle checks again. If still nothing, post a new comment with full details of what you have done and the results.
Nov 17, 2007 | Epson Stylus C40UX InkJet Printer
Printing problem
your printer need head cleaning /
1. Nozzle check monitor the exact color to print / if one of the color missing or line color the printer head ned cleaning ,.
2. Proceed for head cleaning /press head cleaning
3.Nozzle check again after the color complete /test print w/picture
Oct 28, 2007 | HP PSC 2355 All-In-One InkJet Printer
Epson Stylus Color 1160 InkJet Printer Logo
129 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
