Question about NCH Software NCH Tone Generator
NCH tone generator key - NCH Software NCH Tone Generator
How do I fix a Thomas organ that suddenly has all B flat keys, including foot pedal, not working?
get schematic from web search, find tone generator for Bb, look at PCB where connections are for possible cold solder joints or bad tone generator.
Apr 30, 2017 | Music
I want to express Account plus 4.52 License key
NCH is the only place to get it. The key they give you has to match your user information you provide. If you try using someone else's code, it won't work.
Oct 10, 2012 | NCH Software Express Accounts
Key nch software eyeline video system
necesito la clave de eyeline video podria usted facilitarmela
Feb 27, 2012 | NCH Software Eyeline Video System
A gap occur when i change tones on my juno G i.
Yep! When changing VOICE's (we don't call them tones) the generator chips and processing within the synth has to clear out the old voice generation and free up the generators for the new selections. As fast as the processors are, gaps can occur.
Some of the higher end synths are much faster or have so many generators available and processing power that they can do a more orderly transistion.
I am not sure how many generators the JUNO has, but tyoically two are used for every note being keyed. The specs say 128 note polyphony which should be the number of generators... HOWEVER they say these are SHARED with the audio track section. Layering of voices will also divide the number of available generators.
A lot of the arranger keyboards are NOT intended to be played LIVE and as a result transistions of voices are not done on the fly smoothly.
Feb 07, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
Don't have a manual for the Greenlee 77HP Tone Generator
Go through Google type manual for Greenlee 77HP Tone Generator
Jan 09, 2011 | Greenlee 77HP Tone Generator
Won't generate tones from keys when connected
Any other phones on system with the problem?
DTMF or touch tones are generated through the trunk card(s) of the sytem problem. Chances are there may be more then one phone that has a problem.
Also on the outside of things, just try calling the same number from a different phone on the system, and if possible try using the trunk/line that you did with the m7208 in question, same problem? If yes possible trunk issue. If no, then try another phone where the problem set is plugged into.
Another thing you can try is call another service that uses a touch tone menu, using the phone in question, see if you have the same problem.
May 11, 2009 | NorStar M7208 Corded Phone
Is there a way to upgrade the tone generator sounds drums, synths, etc?
No. Unfortunately you are stuck with the drum kits and standard midi that come with the 2488. I find the tone generator sounds to be pretty good on the 2488 quality-wise at least. Of course having the versatility of swapping in other kits and tones/samples would be nice. I believe Tascam discontinued the tone generator/drum machine on subsequent models of 2488 because it seems that the demand wasn't there.
Mar 23, 2009 | Tascam 2488 Portastudio Multitrack...
I am trying to clear my paper work and Have come across documentation regarding NCH Swift Sound. I have registration and Activationcode and ID key. However. I have forgotten what NCH Swift Soundd is. Can...
It could either be for a Sound/Audio editing software or a VoIP software. Pls check their website or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
Top NCH Software Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
richie46
Are you a NCH Software Computer and Internet Expert? Answer questions, earn points and help others
