Question about Iomega (32961) External REV Drive
REV 120 freezes windows explorer in windows 2003
USB REV 120 freezes windows explorer in windows 2003 requiring a reboot. My Computer intermittently does not show a cartridge in the drive even when one is inserted. Clicking on the drive freezes the machine
I have had this problem and found it to be the tapes are the cause.
Last week this same problem happened and 8 out of 10 tapes are causing this freezing suddenly. the other 2 work fine and brand new tapes work fine too.
Posted on Oct 13, 2009
Can't find CD icon is missing from one computer
Windows Key-E will bring up windows explorer which should show your list of available drives.
If this doesn't show your CD drive then try removing CD from drive. Does the disc tray open? If so then reboot system without disc and try the above method to find cd-drive.
If this doesn't work you may need to involve more hands on trouble-shooting.
Thanks
Jul 22, 2011 | Staples 2x1 USB Peripheral Switch
My notino ul100 will not reboot even after the F7 procedure
Remove the hard drive this is very easy. Connect to another pc running xp using a USB caddie. On the notino drive check the windows directory. If you that there are no files only folders then copy explorer.exe to the windows directory. Restore HDD to Notino. Recovery using F7 should work now. This is because the Higrade recovery uses the file explore.exe to validate the destination drive for recovery ( even if file explorer.exe is blank file) This can also be done without removing the HDD. When you get to the screen with the two GREEN pointers move it aside and you will see a dos prompt. Copy explorer.exe from a USB memory stick to D:\windows\ the usb stick should be drive G: Then reboot. It works honestly good luck Switcher
Oct 24, 2010 | Computers & Internet
The USB icon appears; but, cannot access the drive at all. Does not show up as one of the drives. Suspect the drive is toast. Can the drive in the box be replaced with another IDE drive? If so, is...
The Wolverine is a high-speed drive, so try also connecting it to an externally powered "dumb" USB hub. HS spindles may require a slightly higher current and the USB port may not supply it properly.
I have not been able to find the Wolverine's internal HD specs, but the device was reviewed in 2003 and at that date most 2.5" disks were EIDE. While some EIDE drives did have a limitation of 137 Gb of addressable space, this was mostly solved even in embedded chipsets (such as Cypress) by 2003.
So, my guess is that with all probability you can place any EIDE 2.5" drive in the enclosure; if I'm wrong (I think not), the drive will still work and you'll have to repartition it, to only access its first 137 Gb.
Let me know how it goes.
Mar 14, 2010 | Wolverine (3120) 120 GB Hard Drive
Disk does not show in explorer window
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 11, 2010 | Maxtor OneTouch III Mini Edition 120GB...
I have a 2GB microSD card how do I get my music on it from the computer?
Need to purchase a media card reader from a local computer store . Plug unit in a USB port on your computer insert card and use explorer in windows . It should show up as a drive then you will be able to transfer files from computer to card and vice versa.
Nov 18, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Hi Please help - I require a BIOS upgrade
Try first to If bluescreen comes and reboot after to diasble reboot an writing here what on the blue screen they writing.
Other solution maybe possible :
1. Run chkdsk if possible so windows can find erors on the Harddisk.
2. Disconnect all usb except keyboard and mouse
3. uninstall new software installed on the computer (during the last 7 days)
5. maybe it can bee some hardware on the computer that is defect, ex your harddisc/ Dvd drive
Please let mee know if this solve the problem.
Aug 22, 2009 | Computers & Internet
USB Devices: Printer or Memory Stick freezes my XP sp2 on startup
Unplug the offending device(s) from the computer and start it normally. Log on as an administrative user. Open Device Manager. In the View menu, make sure that Show hidden devices is checked. Go through the list of devices and find the problem children. Right-click and select Uninstall for each of them. Reboot the computer. Plug in the devices one at a time and let XP reinstall the proper drivers.
May 29, 2009 | Western Digital My Book Essential Edition...
Intermittent POST issue.
how long does the post takes it to finish before it goes to boot? are there external device connected to your computer like a printer or external hard drive or flush drive? try updating your bios and motherboard chipset.
Jun 12, 2008 | ASUS A8V-MX Motherboard
Cartridges will not stay in & cannot see the device in 2003 enterprise
Turns out the PSU unit was weak. It couldn't provide the power needed to spin up the disks when inserted.
Problem Solved.
Apr 06, 2008 | Iomega REV Tape Drive
SanDisk Cruzer Micro 2 crashes my system!
Hi marykins,
When you say 'crash' does this mean the system reboots, freezes up entirely, or blue screens?
I've seen similar issues when the USB 2.0 host controller isn't enabled in the System (BIOS) setup. Many devices, such as USB mice and MP3 players and even flash drives, will show up and some will function, but if the USB is required to act as a host controller, devices such as external hard drives and (sometimes) flash drives will either not show up at all on the computer or will crash it.
I'd suggest first looking in the BIOS setup to make sure that both the USB host controller and USB legacy support are enabled.
Ben
Mar 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Iomega (32961) External REV Drive Logo
405 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
