Question about Stainless Patio Heaters - Steel Deluxe Residential Outdoor Patio Heater
All pro patio heater pilot light will burn, heater will not ignit
How to fix problem?
  • Frank Schultz
    Frank Schultz May 11, 2010
    What is the problem?
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
hotuna
  • 288 Answers
SOURCE: windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Posted on Mar 06, 2008
AZSTALZ
SOURCE: charmglow patio heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Posted on Nov 09, 2008
co7196
  • 3433 Answers
SOURCE: Charmglow Patio Heater
The yhernocoupler would snuff the pilot if bad. What ignites the overhead burners? and what regulates the overhead gas supply? Look into this. Too much gas will not light as easily as proper balance gas and air. Even more so in a tower type heater.. Turn the gas on low and the pilot should grab it. Good luck
Posted on Jun 10, 2009
co7196
  • 3433 Answers
SOURCE: Main Heater will not light off
turn the gas on real slow. The air in the line is blowing out the pilot
Posted on Aug 26, 2009
Pilot light wont ignite on patio heater
It may be that your cylinder is malfunctioning, cylinder has a leak, or the pilot is clogged. Please see steps below to troubleshoot. Note:Regular maintenance is critical to the successful operation of your patio heater.
  1. Is the cylinder valve closed? If so, open the cylinder valve but not fully.
  2. Check to see if you can light it manually. If the unit lights manually but not with igniter, service or replace igniter switch.
  3. Ensure that there is no air in the gas line. Open the gas line and bleed it (pressing control knob in) for not more than 1 - 2 minutes or until you smell gas.
  4. There may be a blockage in the orifice or pilot tube? Bugs and spiders get into the pilot assembly, venturi tube and burner ports causing the unit to either not light or poor performance.
  5. Is the regulator hose pinched or kinked?
  6. Cleaning the pilot assembly.
  7. If the piezo igniter won't spark to light the pilot, check the wiring to the igniter, It may simply have lost it's ground. Slide the wire off the igniter prong (looks like a thick needle) on the pilot assembly and then push it back on. That usually will reestablish the ground.
If you continue to have problems with the heater, contact Blue Rhino (the manufacturer) Customer Care 800-762-1142.
Hope this helps you to troubleshoot and solve the problem. Please let me know.
Apr 21, 2011 | Uniflame 200209 Open Flame Patio Heater
The pilot seems to light but then when I turn the knob to ignite the main burner, the pilot goes out. Is there a technique to clean the igniting assembly?
let the pilot light burn for a few min and get hot after this try slowly moving the knob over to full burn. Sometimes it just need to heat up.
Feb 14, 2011 | Endless Summer 233000 Open Flame Patio...
On my gas fireplace, the pilot light used to burn blue. Now it's burning more of an orange color. How do I fix it?
needs blowing out remove pilot tube from pilot remove injector and clean it out then replace it all test joint with soapy water to check for leaks
Jan 21, 2010 | Vanguard International Blue Flame - Medium...
The pilot light does not stay on so heater won't light.
to thermocouple where the pilot light sits is either dirty/carbon out of alignment flame not burning on it correctly or damaged/broken which would mean replacement
Oct 19, 2009 | Uniflame Patio Heaters Stainless Steel...
Jun 05, 2009 | Coleman (5040B750) Patio Heater
Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
May 27, 2009 | Endless Summer Blue Rhino 235000...
Pilot lights but burne wont ignite
not that familiar with that particular heater but in most cases if you can get the same length and can mount they are usually the same milli amp and will work remove the old one and take to a good hardware store they can most likely match up one
Dec 18, 2008 | Uniflame 200209 Open Flame Patio Heater
Heating & Cooling Logo
748 people viewed this question
Top Stainless Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
Are you a Stainless Heating and Cooling Expert? Answer questions, earn points and help others
