Question about Siemens Washing Machines
What does this error code e3 mean model WM08G260IN
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Code E3
The Machine control is attempting to drive the motor but is not seeing any tachometer response or motor action. It could have a failed tachometer/hall sensor which is part of the motor, failed motor or machine control. It could be a loose wire connection at the motor or at the machine control board. This type of failure will require a technician to diagnose and repair your washer. I recommend calling a service technician.
Posted on Jan 10, 2009
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
SOURCE: e3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Posted on Dec 21, 2009
headstrong56
  • 493 Answers
SOURCE: I have a washing machine with code E3. What does this mean?
It can be the motor, control unit or the wiring and connections
Read more: http://forum.appliancepartspros.com/washer-repair/403943-having-e3-code-my-maytag-mah8700ww-washing-machine.html#ixzz215i5QiDy
Posted on Jul 19, 2012
Model wf361. What is causing e3 error?
e3. Drive motor tach fault. This means that the tachometer is not regitering any motor movement when it should. Main reasons for samsung: motor control board fault. Tachometer fault. Motor fault. Also check wireing from motor control board to motor. But this issue is not common at all with samsung.
Feb 15, 2016 | Samsung Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
AC has been woking great for two year. Now has error code E3- evaporator error
mfr. model no.? some mfr., e3 means low pressure. may need sufficient refrigerant, otherwise suspect the pressure switch.
Oct 13, 2015 | Heating & Cooling
What is error code E3 on Wristech wrist blood pressure monitor Model HL 168ZA
The E3 Fault Code means Error in determining measurement data. In which case, measure again. If this continues to happen contact HoMedics Customer Service @ 800-466-3342.
http://blog.suntechmed.com/blog/23-abpm/310-top-5-reasons-your-automated-bp-monitor-gave-an-error-code
Feb 25, 2015 | Health & Beauty
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
Voltas vertis error code E3. what does it mean
Unfortunately, Haier for whatever reason, does not include any of the error codes in their literature. To find out what E3 means and the solution, contact Haier Customer Support 1-877-337-3639, Have the correct model number handy when you call.
I hope this helped you and thanks for choosing FixYa.
Aug 19, 2011 | Haier Energy Star ESA3183 Air Conditioner
Getting code E3. What does this mean?
error E3 means Paper jam ..try to clean any paper inside...
May 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E3 error code will not wash, what does this error code mean?
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenwood dishwasher kdw12st3a error code e3, what does this mean ?
in the manual I have for this machine model E3 means: Longer heating time but not reaching requied temperature. The possible causes: malfunction of temperature sensor or of heating element
Aug 01, 2008 | Dishwashers
Washing Machines Logo
138 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
