Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Replacement of mower wheels
I want to know how to replace a plastic wheels on my push lawn mower with round circ clips.
    Scholar:
  • 81 Answers
You have to pop the clips off the outside of the wheels. There may be a plastic over on each wheel that has to be removed first, but without a model number I'm not sure it your mower has them. If you don't break any of the clips they can be reused.
Posted on Jun 23, 2009
How do you replace primer bulb on model 917.385125 B&S 550 series motor on a Craftsman mower?
the old primer ball is held in place with a round retaining clip remove it just use a sharp screw driver to pry it out then pull out old primer buy new primer and retaining clip put primer in the take a socket that is the same size as ring and that will slip over the primer push the ring in till it seats
Sep 13, 2014 | Craftsman Garden
How to replace wheels on Excell VR2522 pressure washer
Anon, The wheel is probably held on by a push nut/cap. The easy way to remove is to cut through the cap retainer with a dremel tool part way and pry off with screw driver, these caps are not normally reusable after removal, check hardware store for replacement.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeVilbiss Excell VR2522 Type 0 Gas Pressure Washer Parts
Remove CM 1200 Lawn Mower Wheel Retainer Clip on Lawn Mower Wagon Carriage...
https://answers.yahoo.com/question/index?qid=20130208122204AAcj7mW
Jan 28, 2013 | Garden
How to replace the fuel primer button on a Briggs & Straton 38 sprint motor
They are usually held in with either a small, round metal spring clip or a plastic one. A small dental type pick with an "L" shape at the end is often all you need to pry out the clip.
Aug 24, 2012 | Garden
Anybody know how the horn wiring behind airbags is supposed to go? 1998 Chevy cavalier 2.2L. I'm replacing the airbags cover and don't know where the wire and ground goes...(
It is really very simple. The horn lead with the plastic connector and the spring pushes in and turns to lock in the large round hole at the upper left center of the steering wheel. If you look into the hole, you will see the contact down in there with a plastic "tube" with a slot in it for the horn connector to go into.
The ground clip (wire with brass or steel clip on it) simply pushes into the hole in the steering wheel center near the bottom (It grounds to the steering wheel center).
Feb 21, 2012 | 1998 Chevrolet Cavalier
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
I have a craftsman self propelled lawn mower The clip that holds the metal bar to make it go forward broke the speeds don't change it is difficult to pull backward the wheels won't move
i have a craftsman rope start lawn mower, the rope keeps snapping back on me and sometime will not come out at all. is there a way to fix this problem
May 18, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Rear wheel drive does not push mower when engaged. But, when mower rear wheels are lifted off the ground, they turn weakly.
remove the rear wheels and check the gears in the wheels- they are plastic and part of the circumfrance on the inside of the wheel. If worn replace wheels.
also check belt- it should be tight with very little play when drive is engaged ( obvioulsy check this with engine off).
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Both front wheels on my craftsman self propelled lawn mower are stripped. How did that happen and what do I need to do to keep the new set of wheels from finding the same fate?
Sears self propelled.......metal gear with plastic wheels.......does ANYONE else think this is ASSINNINE? Typical American cheap azz shyt.
Aug 21, 2009 | Poulan Pro " Pro" Self Propelled Mower
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
207 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
