Question about Polaris Pb4 - 60 Booster Pump
Polaris booster pump turns on for about 3 seconds. then its pops off. but it doesn't trip breaker and in about one or two minutes you can hear it click and reset itself. you can then turn it on and it will do the same thing.
    Genius:
  • 1,114 Answers
That click you hear is the pump's breaker, or thermal overload kicking in. After about one minute, the pump has cooled down again.
I believe this type of pump is not self-priming, and therefore, it needs to be primed and purged of air. If it is not a self priming pump, there should be a small plug on top of the pump housing. Remove the plug, and add water from the top opening until the water overflows, and then replace the plug. Or, if when you remove the plug, water comes out the top opening, let it flow for a few seconds, and then replace the plug.Then, turn the pump on.
Hope this was helpful...
Posted on Jun 28, 2009
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
Posted on Jun 14, 2009
Are there any other booster pumps that I can use to run my pool cleaner? I had a Polaris bp4-60 for 7 years, it finally failed. Replaced it with same model. Ran for few mins then shuts off then restarts....
I think Polaris should refund the purchase price on these pumps. I changed the breaker, the whip, and upgraded the outlet (using 110). The dealer exchanged it for me, but would not give me a refund, and I had the same issue with the second motor. I used a Hayward 6060 pump as a replacement. Everything works fine.
Jul 04, 2014 | Polaris Pb4 - 60 Booster Pump
Polaris Booster Pump PB4-60 Overheating
see side of motor make sure wiring correct if ok maybe you got a bad one
Aug 29, 2012 | Polaris Pb4 - 60 Booster Pump
New polaris pb4-60 booster pump shuts off when polaris recycles, why?
sounds like weak motor the back pressure is overheating the motor replace
Jul 14, 2012 | Polaris Pb460 Polaris Booster Pump...
I have a Polaris PB4-60 booster pump, less than 3yrs old. I turned the pump and left. When I got back 1hr later, the pump was not running. Breakers had been tripped. Each time we reset the breakers and...
If the device that tripped is a ground fault circuit interupter (GFCI) breaker or receptacle then it is likely caused by 5mA or more of leakage current to ground within the motor. If what tripped is a circuit breaker then there are likely shorted turns within the motor. Usually either of this issues requires a new motor.
If you are not wanting to turn wrenches yourselfthen my best suggestion is to bring it to Leslies Pool Supplies and they oftencan put it right for the price of the parts while you watch (they might not have some parts in stock).
I hope this helps.
Sep 27, 2011 | Polaris Pb4 - 60 Booster Pump
There was a freeze recently that busted my pipes. i fixed the pvc and tried to turn the pump on and nothing happens, silence.... The breakers are on amd the polaris booster pump works... however the 1.5 hp...
1. Is there a switch on the bottom of the pump?
2. Hearing nothing indicates no electricity to the pump.
3. Is there some other location where power could be off or tripped off?
Gary
Feb 21, 2011 | Hayward Pool & Spa
Installed a new 3/4 hp Polaris pool sweep pump.
Check your voltage and be sure it matches the way the motor is wired. You will find a scematic for this on top or on the side of the new motor, with a diagram on how to rewire it if nessary. If this is not the problem then it is in the motor and should be returned for a new one.
Dec 19, 2009 | Polaris Pb460 Polaris Booster Pump...
Pump comes on for about a minute...then shuts off..
Has this pump worked at all -pumped water?
When it's running for about a minute, is it pumping water?
Is this a self priming pump or do you need to prime it?
Jun 28, 2009 | Polaris Pb4 - 60 Booster Pump
POLARIS PB-4 3/4 HP BOOSTER PUMP -- body of pump very hot, too hot to hold hand on. 20 amp breaker gets very hot also. Has not tripped the 20 amp breaker yet.
A motor can run that hot and still be within the temperature it can handle. It likely has an internal overload device that will shut it off if it exceeds that temperature. If you see something like "thermally protected" on the motor nameplate, you are ok. If it is getting noisy as it runs it may need servicing.
Jun 08, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris booster pump overheats and trips the breaker
May 29, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris Pb4 - 60 Booster Pump Logo
490 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
