Question about RTO Plumbing
Hunter Psr-22 Pump Start Relay - RTO Plumbing
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: I have installed a Hunter
So the mv and c are supplying power to the transformer/relay and out of it, but the pump won't start until the relay is forced.
I'm thinking the relay contacts are oxidized, and need to be cleaned. When they have oxidation, current goes up, and voltage might appear ok. If any start capacitors are in the circuit, they can be faulty, breaking down under a load, while reading ok. I haven't heard of any caps in these systems, but just in case.
The following blog may help you- it's about different controller situations:
http://forums2.gardenweb.com/forums/load/water/msg121639307045.html?9
Hunter's website has some things to check concerning the controller:
http://www.hunterindustries.com/resources/library/product_technical.html
Looks like it could be microprocessor lockup. It's quite a process, but here's what they say is the fix:
http://www.hunterindustries.com/resources/library/Technical/200611_hdln_micropro.html
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 14, 2010
Where is the ECM fuse and Fuel pump relay on a 2000 Hyundai Tiberon?
images for Where is the ECM fuse and Fuel pump ..
ECU fuse keeps blowing - New Tiburon Forum : Hyundai Tiburon ...
www.newtiburon.com/.../tiburon.../217243-ecu-fuse-keeps-blowing.html
Sep 8, 2012 - 18 posts - ‎8 authors
Edit: Instead, pull the fuel pump relay, and see if the fuse still blows when ... ControlRelay, Fuel Pump relay, A/T control relay, Generator, ECM ... Official "Check Engine Light" Thread - New Tiburon Forum ...
Jul 22, 2014
Fuel pump Relay
Apr 26, 2013
Starting problem. Fuel pump doesn't prime with key on.
Mar 9, 2013
Fuel pump not starting intermittently
Oct 6, 2010
More results from www.newtiburon.com
Car Cranks But Will Not Start - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/...2000.../85246-car-cranks-but-will-not-start...
Jan 17, 2008 - 10 posts - ‎6 authors
Jan 06, 2016 | Hyundai Cars & Trucks
Irrigation valve vibrates when opening.
Take apart and clean spring /diaphragm is sticking
Clean unt out
Feb 18, 2013 | Hunter Industries Hunter NODE-100 Single...
How does power get to fuel pump? Are relays involved?
There is a fuel pump relay and a fuse...In the under-hood fuse box, fuse #22 (20 amp) powers the fuel pump relay. The best method of ensuring the fuel pump is getting proper voltage is testing for power at the intertia switch (fuel cut-off in case of an accident). It is on the driver's side of the trunk behind the liner. Ground a test light and have a assistant cycle the key. It should be powered for about 3-5 seconds initially after the key is cycled to the start position.
I hope this helps.
Jul 24, 2011 | 2001 Lincoln Town Car
I have a 1993 VW Passat VR6, My problem is when I try to start it, I have no spark from the spark plugs..What could be the problem or how do I fix this?????
GO TO THIS SiTE TO CHECK THE FUSE BOX!
http://vwtech.no-ip.info/images/golf/post90.gif
This are the FUSE and RELAY number SLOT!
Fuse No. Description Ampere Rating 1 Headlight, low beam, left 10 2 Headlight, low beam, right 10 3 Instrument panel lights, license plate lights 10 4 Glove compartment light 15 5 Wiper/washer 15 6 Fresh air blower 16-valve only: Air conditioning 20 7 Taillights, side marker light, right 10 8 Taillights, side marker light, left 0 9 Rear window defogger 20 10 2.0 16-valve only: Fog lights 15 11 Headlight, high beam, left,High beam indicator light 10 12 Headlight, high beam, right 10 13 Horn 16-valve only: Radiator cooling fan 10 14 Back-up lights, washer nozzle heaters 10 15 2.0 16-valve only: Engine electronics, stabilizer valve, cold start valve 10 16 Instrument panel warning lights, 16-valve only: Multi function indicator 15 17 Emergency flasher switch, turn signals 10 18 Fuel pump, oxygen sensor heater 20 19 Radiator cooling fan, air conditioning 30 20 Brake lights, cruise control 10 21 Interior lights, digital clock 16-valve only: Luggage compartment light,multi function indicator, central locking 15 22 Radio, cigarette lighter 10
Relays Relay No. Description 1 Air conditioning 2 Open 3 Digifant control unit 4 Load reduction relay 5 Low coolant level control unit or Open 6 Emergency flashers 7 Rear Wiper 8 Intermittent wipers 9 Seat belt warning system control unit (possibly headlight warning too?) 10 Fog lights 11 Horn 12 Fuel pump (except diesel)Glow plugs (diesel) 13 Radiator cooling fan after run (except 16-valve)2.0 16-valve: Starter interlock relay 14 Automatic trans., coolant temperature indicator,starter interlock relay (except 2.0 16-valve)2.0 16-valve: Radiator cooling fan after run 15 ABS pump relay 16 ABS relay 17 Heated seat control unit, driver 18 Heated seat control unit, passenger, or power seat circuit breaker 19 Automatic transmission 20 Open 21 Power window relay, ABS hydraulic pump fuse 22 ABS valves fuse 23 Air conditioning, power seat fuse 24 Power window fuse
Nov 17, 2010 | 1993 Volkswagen Passat
I have installed a Hunter psr22 pump start relay and connected it to a Hunter src irrigation controller and when I cycle the irrigation controller to manual all stations it will not start the pump. There...
Sep 14, 2010 | RTO Hunter Psr-22 Pump Start Relay
Why my PSR-22 pump start relay does not start the pump even the automatic sprinkler controller is at manual run mode?
It could be that the PSR-22 isn't "relaying" the correct amount of power to your pump. If the PSR-22 is making noise (a hum, or buzzing sound), it could be failing.
Try checking the voltage on the PSR-22 to be sure that it's supplying your pump correctly. Be careful - there's a lot of voltage in there, and getting a shock could be fatal.
Jul 11, 2010 | Hunter Pump Start Relay Psr-22 Pump...
White-Rodgers 1F58-58 to Hunter 44660
This is the corrcet wiring:
G - G fan relay
R - RC1, RC put a jumper RH ( to supply power to the cool and heat)
L - no wire connected (malfunction indicator) tape- off that wire
E - Emergency heat relay
B - W/B ( reversing valve in your heat pump energized during heat )
W2 - Auxilliary heat
Y - Y1 ( compressor contact)
O- Y/O ( reversing valve is energized during cool)
make sure that the system selector is on heat pump position.
Apr 30, 2009 | Hunter Fan Company 5/1/1 Programmable...
Relay and fuse for the fuel pump
The fuel pump relay is in the black box under the hood by the battery. #22 (fuel pump - PCM) & #27 (fuel pump) are for the fuel pump.
It says there is a 15 amp fuel pump circuit fuse in the interior fuse panel on the dash panel by the drivers knee location. I could not find it but here is the picture.
Feb 19, 2009 | 1996 Nissan Quest
1992 XJ6 fuel fail code 22
FF22 is Fuel Pump Drive failure
ECU looks for sognal to the fuel pump relay.
found in jaguar-forum:
"I'm 99% sure that you have a bad fuel pump connector sending a high resistance fault to the CPU. Check your fuel pump connector at the pump. There is a very short harness in the trunk behind the spare tire and the panel behind it. I think the wires are red and blue? Anyway, the tough part is where they tend to go bad is actually at the pump in the top of the tank. You will not be able to get to it unless you have very small hands. You can get to it easier by dropping the tank a little, you probably won't have to remove the lines, just the tank straps. I have seen this connector overheat and burn. Try and clean it up and apply white grease to it.
If you start to have stalling problems in the future, strongly suspect this. Jumping the fuel relay gave me a little extra juice to the pump so I could move the car."
Oct 18, 2008 | 1992 Jaguar XJ6
Plumbing Logo
66 people viewed this question
Top RTO Plumbing Experts
Donni Steen
Tom Chichester
Are you a RTO Plumbing Expert? Answer questions, earn points and help others
