Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
Problem with 40 GB Transcend external HDD
I have problem with my 40GB Transcend external HDD, It is corrupted, how to recover it?
  • 400 Answers
Get it format and then use Data doctor recovery software to get the data back....
Posted on Jun 23, 2009
    Sergeant:
  • 220 Answers
Try using a repair checkdisk by
  1. Going to start menu
  2. Click run
  3. Type chkdsk /r X: (where X is the drive letter)
  4. hit enter
  5. wait it finishes
Good luck
Where can i find the Transcend 320 GB format utility software?
Your computer can format the hard drive. If you want to recover the software on the hard drive you'll have to contact the manufacturer. You can use the drive after reformatting it. The software is on a separate partition so you may be able to recover it by using a data recovery program.
Jun 20, 2015 | Transcend Computers & Internet
I am using Transcend 320GB USB hard disk. Contents of few folders are accessible and some are not. when i try to open the folder whose contents are not visible, a message pops up saying that disk is not...
Did you try running software from windows to try repairing it? disc scan etc, There is plenty of help on your computer or on the net to repair lost or corrupt files and most of it is free, Treat it like it is the internal hdd on your own computer but tell your computer to scan that disk instead of its own internal hdd, it does work as i use this method myself, Go to start-my computer-you should see your external hdd there, Right click and go down to properties, Click on that and go to tools, Use tools from the drop down menu and try repair it from there, There will be one called check now and tick both boxes, Hope this helps,
Sep 19, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
When I connect my transcend 320gb external drive to my mac, the drive light just flashes, and doesn't connect to the mac for backups
This could be a couple things since it's an external HDD. Here's what I would try:
  1. Try another port
  2. Try another cable
  3. Remove the drive from the external case and plug it in to the MAC directly if possible. If not possible, get another external case for it (they're not expensive these days)
  4. If you still do not get the drive to come up after that, then you might want to give SpinRite a try. http://www.grc.com - it costs $89, but it is a tool everyone should have around in my opinion.
    Keep in mind that new drives are cheap. a 2 TB hdd will run you about as much as SpinRite. But getting a new drive will NOT recover your data of course. So if that data is important to you, see if you can recover it with SpinRite, the team over at GRC is awesome when it comes to support as well.
May 19, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Folder dissapear only some open file are ther and drive show 80 % full
Most probably your PC & external HDD is infected with dangerous objects/files eg. virus, malwares, etc... which resulted your folders & files atributes changed to "hidden".
Do a thorough Virus/Malware scan for the PC & External HDD, to removed the "dangerous object/files"
Refer to this thread how to recover your "hidden" folder/files @ Reset System and Hidden Attributes for Files or Folders Caused by Virus
Hope it helps
Apr 29, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My external hard drive was damaged i wont recovery from hard drive.
Depending on the severity of the damage you have a couple of options.
1) Put the HDD inside a airtight bag and place in a freezer for at least 4 hours. Remove the HDD from freezer and see if it works. If it does start to work you will have a limited amount of time to recover the data.
2) Pay Data recovery company to recover the data
http://www.ontrackdatarecovery.com/
Mar 06, 2011 | Transcend 160Gb StoreJet 25 Unveils Rugged...
Hi.. i need help.. my external hdd transcend store jet 320gb have problem... when I conect HDD to pc blue led blink just one time and hdd stop working..
Check that the USB cable can provide enough power to the hdd. Check that the USB port is powered. Older USB slots may not have enough power to run larger external HDDs, there you may require separate power to be plugged into the hdd. Are you using the original USB cable provided with the external HDD?
Feb 28, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Transcend 500 GB External HDD is detected but doesnt show the data in it.
Your external HDD may be corrupted. Recover the data before you use it.
First things first: STOP using the external hard dive that you want to recover data from in case you may quite possibly ruin your chances of data recovery.
Then Recommend you have a try of Wondershare Data Recovery, a data recovery program with both Windows and Mac versions provided. It should help you. Get the related versions here,
Data Recovery Windows (for Windows)
Data Recovery Mac (for Apple Mac OS)
Remember - Do NOT try & write anything back to your hard drive until you can recover your data safely!
Nov 20, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hello, I own a Trancend 40Gb PORTABLE USB DEVICE. I am facing problems to access my files. I connected to my pc using both USB & Electrical plug withoyt any success. The device dowes not appear in...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Aug 24, 2010 | Transcend (TS40GSJ25) 40 GB Hard Drive
Installing new Acer Aspire 3200LCi Hard drive
try the jumpers set its th masterand slave thing
Feb 24, 2009 | Acer Aspire 3002LCi Notebook
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
256 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
