Question about Briggs & Stratton Garden
How does the gearbox drive an old mountfield 7hp
I need a parts manual for a rototiller Gilson 7Hp model 462 42045 with a serial number 920437
Give this a shot. not sure what your after (I know parts manual) but availability is vauge----they do have sections with info of certain items pertaining to your tiller---you may be led to what you need
https://www.google.com/search?q=parts+manual+Gilson+7Hp+model+462+42045+tiller&rlz=1C1NHXL_enUS713US714&oq=parts+manual+Gilson+7Hp+model+462+42045+tiller&aqs=chrome..69i57.15739j0j9&sourceid=chrome&ie=UTF-8
Jun 11, 2017 | Gilson Garden
How to remove lower unit from leg of 7hp. eska sears outboar
Don't know if this will help, but there are some educational videos on YouTube:
https://www.youtube.com/watch?v=HRpfaOiXxWo
I hope this helps you out!
Feb 12, 2017 | Sears Garden
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
Parts not available for Ariens ST724 7hp snow blower?
As far as the bolts you should be able to match them at a small engine and lawnmower repair shop and as well if you take the old recoil they might be able to get you what you need.
Nov 10, 2014 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
I require parts No for OPC/Clutch cable Holder/bracket for Mountfield Mower Model SP480T
Please see www.jungle-busters.co.uk/Mountfield-Cable-Holder for also very handy for any other mountfield mower spares
Oct 01, 2010 | Garden
How much gear oil goes into Mountfield tiller gearbox. There is a plug for filling but I have no idea what the level is. Roger.
It is usually the plug is the full gauge. Fill it right to the top. It should be about 1 1/2 inches above the bottom of the motor, maybe more. Hope this helps.
Mar 27, 2010 | Garden
I have a 7hp briggs and straton craftsman self propelled push mower. It's a few years old but runs great, the only thing wrong is the self propelled part won't engage. I took it apart down to the axle but...
Could be a stretched out/broken belt, a worn out transmission or the drive teeth on the inside of the wheels could be worn out. I would start by looking at that. Remove the drive wheels and check for damaged or missing teeth.
Apr 20, 2009 | Craftsman Garden
Garden Logo
11 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
