Question about Fudge Headpaint Hair Color 5.73 Light Tobacco Brown
Is fudge 5.73 a semi?
Is this a semi or permanent?
How can i ship fudge to a friend in Maine without it melting? thanks!
Pack it in dry ice. Be sure both the dry ice and the fudge are well wrapped separatly.and insulation material around both. How much dry ice you ask? If you wrap a small chunk of dry ice with several wraps of newspaper it should last quit some time. It sounds like a trial and error problem. Where to buy dry ice? It's hard to find but stores that use it might sell some.
May 21, 2015 | Pecans.com Homemade Fudge 1 lb
How can I make my own makeup?
http://thecoconutmama.com/2015/03/homemade-natural-makeup-recipes/
Mar 16, 2015 | Health & Beauty
SOFTLY WE DIP HERS IN FUDGE
So you're dipping a laptop in fudge and wondering why it doesn't work?Excellent. Take it back to the store and get them to fix it under warranty! :-)
Oct 07, 2014 | Computers & Internet
The grey in my relaxed brown hair occasionally turns a greenish color I use adore semi permanent, dark chocolate any idea how to avoid this?
Your hair is turning green because your missing red when you color your hair. Gray is uncolored hair and to get to a dark chocolate brown you need to add a little red to the color to make up for this. You don't need to strip it out.
Have you heard of people using purple shampoo to neutralize the yellow tones of their blonde? Red will neutralize the green tones, so adding a little red to your color will do this for you.
Mar 09, 2014 | Adore LVT Semi Permanent Hair Color 112...
Do demi-permanent hair colors have ammonia in them?
No, demi- permanent hair colors should not have ammonia in them although they do have some peroxide in which is why they last for about 28 washes as opposed to semi-permanents which only last for 6-8 washes.
Mar 04, 2013 | Health & Beauty
Need directions for iso nexture semi-permanent texturizing treatment
Texturizing is the SAME thing as relaxing... same chemical and everything it's just milder (usually mixed with an oil to slow the process of relaxing down a bit)
DO NOT let you texturize your hair! Perhaps you can make an agreement to wait until after you big chop to decide to texturize or not? Even then I wouldn't recommend doing it.if you have more side effact you need a homeopathy medicin you buy this on http://www.homeoinformation.blogspot.com (sabadela30)
Oct 04, 2011 | Iso Nexture Semi permanent Perm Normal...
How do you remove the yellow tint from gray or silver hair?
You can only remove it by bleaching it. Usually though, we merely neutralize yellow by applying a permanent tint, demi-permanent color, semi-permanent rinse, or a colored shampoo in a complementary color, that is a hue that is opposite yellow on the color wheel. The hue most often used is violet.
Apr 10, 2011 | Health & Beauty
How to make fudge.
There's many videos on YouTube on how to make fudge, here are the most popular two videos:
and here is the other one
Dec 15, 2010 | YouTube Videos
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
Fudge Headpaint Hair Color 5.73 Light Tobacco Brown Logo
85 people viewed this question
Top Fudge Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Fudge Health and Beauty Expert? Answer questions, earn points and help others
