Question about HP Computers & Internet
HOW TO REMOVE GROUP POLICY FOR USEB RESTRICTION FOR CLIENT USER
    Scholar:
  • 46 Answers
You will need administrative access to modify any group policies.
From the command line run gpedit.msc. Since you are not listing a particular group policy I can only suggest that you bring up all settings, and then sort them by state. All enabled policies will rise to the top of the list. You can then disable or modify the policies as needed.
Posted on May 02, 2016
How to fix access denaid probems.
Open the Local Group Policy Editor Applies To: Windows 7, Windows 8, Windows Server 2008 R2, Windows Server 2012
You can open the Local Group Policy Editor by using the command line or by using the Microsoft Management Console (MMC).
To open the Local Group Policy Editor from the command line
  • Click Start , type gpedit.msc in the Start Search box, and then press ENTER .
To open the Local Group Policy Editor as an MMC snap-in
  1. Open MMC. (Click Start , click in the Start Search box, type mmc , and then press ENTER .)
  2. On the File menu, click Add/Remove Snap-in .
  3. In the Add or Remove Snap-ins dialog box, click Group Policy Object Editor , and then click Add .
  4. In the Select Group Policy Object dialog box, click Browse .
  5. Click This computer to edit the Local Group Policy object, or click Users to edit Administrator, Non-Administrator, or per-user Local Group Policy objects.
  6. Click Finish .
Jan 28, 2016 | Computers & Internet
Tip
Fix Windows 7 Error ?Windows is Not Genuine? Error code 0×80070005
Those users running genuine version of Windows 7 provided with their hardware platform reported that immediately after log on they were presented with following error message. “Windows is not genuine. Your computer might not be running a counterfeit copy of Windows. 0×80070005.”
Some other symptoms of associated with this issue are,
The computer desktop background is black, and you receive the following error message on the bottom right corner of the screen:
“This copy of Windows is not genuine”
You receive the following error message when you view the System Properties: (Control Panel / System and Security / System)
“You must activate today. Activate Windows now”
If you try to use slmgr.vbs /dlv to view the licensing status, you receive the following message:
Error: 0×80070005 Access denied: the requested action requires elevated privileges
Microsoft is fully aware of this issue and provided following explanation for the issue,
There is a lack of permissions in the registry key HKU\S-1-5-20. The Network Service account must have full control and read permissions over that registry key.
This situation may be the result of applying a Plug and Play Group Policy object (GPO).
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B).
Method A: Disable the Plug and Play Policy
1. Determine the source of the policy . To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to “Not Defined.” Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy:
1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template, Query status, Enumerate dependents, Interrogate, User-defined control, Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)
(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)
(A;;CCLCSWLOCRRC;;;IU)
(A;;CCLCSWLOCRRC;;;SU)
S:(AU;FA;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;WD)
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to “SU” (SDDL_SERVICE – Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO’s in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
1. On the computer that is out of tolerance, start Registry Editor.
2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions…
3. If the NETWORK SERVICE is not present, click Add…
4. In Enter the object names to select type Network Service and then click Check Names and OK.
5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
6. Restart the computer.
7. After the restart, the system may require activation. Complete the activation.
on Jul 15, 2010 | Computers & Internet
Tip
Method A: Disable the Plug and Play Policy 1. Determine the source of the policy . To do this, follow these steps:
Method B: Edit the permissions of the Group Policy: 1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
sc sdshow plugplay
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
on May 19, 2010 | Computers & Internet
Turns on goes to user screen when i put password in it says group policy client service failed access denied
Sounds like you'll need to make another user account, then try to remove whatever rights the problem account has. You could try going to microsofts help page and type the statement exactly, include error codes if there are any, or, try this, http://windowshelp.microsoft.com/Windows/en-US/Help/769495bf-035c-4764-a538-c9b05c22001e1033.mspx
Hope you get it fixed, Grim
Aug 19, 2015 | Computers & Internet
I cant logon to my user, the message is The Group Policy Client Service failed the logon. Access is denied
I think that it is possible because of the client server isn't running. Try contacting your administrator.
Jul 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to Solve " Registry Editing has been disabled by your Administrator"
Methods to Remove the Registry Editing Restriction
Method 1 :- Using REG.EXE Console Tool
  • Click Start, Run and type this command
REG add HKCUSoftwareMicrosoftWindowsCurrentVersionPoliciesSystem /v DisableRegistryTools /t REG_DWORD /d 0 /f
You should be able to launch Tweak UI, as well as the Registry Editor.
Method 2 :- Using the Group Policy Editor (Windows XP Only)
  • Click Start, Run and type gpedit.msc and press Enter
  • Goto the following location User Configuration | Administrative Templates | System
  • Double-click Disable Registry editing tools and set it to Not Configured
  • Exit the Group Policy Editor
Note:- If the setting already reads Not Configured, set it to Enabled and click Apply . Then revert it back to Not Configured. This ensures that the DisableRegistryTools registry value is removed successfully.
on Jan 12, 2010 | Computers & Internet
THE GROUP POLICY CLIENT SERVICE FAILED
I wouldnt worry about it its only used on a corporate network for group policy downloads to your laptop.
If you are on a corporate network check the service dependencies in the services applet in control panel. It may be another service that has been disabled or failed that is preventing GPO client service from failing.
Apr 02, 2014 | Dell Inspiron 1545 Notebook
I cant install service pack3 for win xp because error 0x800a0046
Try this method
* Remove the user account that is experiencing difficulty from the Guests
or Limited account groups
Click Start, click Run, type control admintools, and then click OK.
Click Computer Management.
Expand Local Users and Groups.
Select Users.
Open the account that is used to access Windows Update.
Click the Member Of tab.
Select the user account that you want to remove, and then click Remove.;
* Add the Local Administrator and Service accounts to the Impersonate a
client after authentication policy
Click Start, point to All Programs, point to Administrative Tools, and
then click Local Security Policy.
Expand Local Policies.
Click User Rights Assignment.
Double-click to open the Impersonate a client after authentication
policy
On the Local Security Settings tab, click Add User or Group, and then
add the Administrator and Service to the list of Users and Groups.
Click OK, and then restart the computer.
good luck
Jun 27, 2011 | Computers & Internet
I have genuine windows 7 but computer says that it is not genuine
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B). Method A: Disable the Plug and Play Policy
1. Determine the source of the policy. To do this, follow these steps:
a. Edit the Group Policy that is identified in Step 1 and change the setting to "Not Defined." Or, follow the section below to add the required permissions for the Network Service account.
Query template
Query status
Interrogate
Read permissions
sc sdshow plugplay
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to "SU" (SDDL_SERVICE - Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
Note: If there are no GPO's in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
  2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions...
  3. If the NETWORK SERVICE is not present, click Add...
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 13, 2011 | Microsoft Windows 7 Ultimate 32 & 64 BIT
Logging on to server
You need to go into administrative tools and look for group policy.
In the local computer policy
Windows Settings > security settings > Local policies > user rights assignment. In the right hand pane find the policy for "Allow log on locally" Set the user accounts for those users which are allowed to log on interactively on the server. Be careful you dont lock the administrator account out.
Use in conjunction with the "Deny logon locally policy" if you need to.
Hope this helps
Mar 22, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
