How fix level problem ? - Audio Players & Recorders
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
Could you please a little more specific?
Posted on Aug 08, 2015
Why is my deck not controlling my subwoofer level?
If your Sony receiver has a separate sub output, it probably has a fixed level for application to a powered sub. Your mono amp can only boost the fixed signal level it receives from your receiver. The receiver can't drive that mono amp harder
Jun 05, 2013 | Sony MEXBT5700U CD Receiver Bluetooth...
Subaru Forester 2007 fuel gauge level jumping
This problem, is caused by a defective gas level sending unit inside the fuel tank. You must remove the fuel tank from the car to replace the level sensor.
Sep 05, 2012 | 2007 Subaru Forester 2.0
Replacing toilet and flange is not level by 1/4
for a quick fix bolt down as usual, then use pennies to prop toilet up level. once level tighten bolts. dont over tighten. once finished caulk around the toilet to conceal pennies. they r copper so they dont corrode as fast. or for a better fix, they sell small plastic wedges just for that issue that will stay in place on there own.
Mar 17, 2012 | Plumbing
I have a berger instruments transit level model 200B and have no cross hairs to center it when i look through it , is there a fix??
Yes there is, but I don't think you can do it your self. There are places that fix nothing but levels and transits. I don't know what happened to your lines, must have been dropped or something. I had a level repaired once, it was fairly cheap. I would contact Berger first. Hope this helps.
Aug 09, 2010 | Speed Berger Instruments Line Transit -...
I am trying to fit a plastic bath panel i have got all the fixings but havnt a clue how to do it! can anyone help?
Assemble the legs & fix to the bath. Leave the adjustment nuts a little loose. Fit taps and waste. Place bath in position. Use a spirit level to ensure lever both front to back and sideways using the adjuster nuts to get it level. Start at one end near the wall and level to the other end against the wall then level sideways. Then check all levels again.
Further help --- rod_davies@hotmail.com
Mar 10, 2010 | Home
MY 2002 GRAND CHEROKEE BLOWS OUT COLD AIR NO HOT AIR WHEN I TURN THE HEAT ON WHAT CAN I DO TO FIX IT OR HOW MUCH WILL IT COST ME.
First thing you do is check the antifreeze level. Is the plastic overflow tank up to the level on the tank? You will see a mark for the level it should be if cold and a level it should be if hot. If it is low, add antifreeze to the tank as well as the radiator (take radiator cap off while engine is cold). Get the level up and that should fix the problem. If it doesn't, or the level of antifreeze is where it should be, then you could have a thermostat that is stuck open which doesn't allow the coolant to warm up before being circulated. Replace that and I would bet you have all sorts of heat coming. Both of these fixes are very easy on the bank account.
Good Luck
Dec 16, 2009 | 2002 Jeep Grand Cherokee
Engine hot ... heater cold ?
Check the coolant level, it could be as easy a fix as adding coolant because it's low. Low level causes engine to overheat, and low level won't circulate to heater core, so no heat situation even though engine is running hot. Let me know if this fixes it, if not I'll help .
Nov 28, 2008 | 2000 Ford Taurus
Kenmore 90 series top loader washer water level.
There are easy checks before you replace the level selector body
remove the trim plates at both ends of the control panel to expose Phillips head screws 1 at each end. remove the screws
lift and swing the control panel up and over the back, it is hinged at the top.
The washer can be operated in this condition for testing
1 Rremove the air hose, and blow it out.
often water remains in the tube after changing levels, the water is not compressible so a small change in water level in the tank, makes too much difference in the sensor.
reconnect the tube and try a cycle ~1/3 chance of fixing it
If fail,
2 The spring inside Kenmore water level sensors that reacts to air pressure in the tube is not up to the job and stretches, not noticeable till changing water level settings moves the anchor point of the spring.
pull off water level knob from control panel front, from control panel back depress lock tab at right of level selector body rotate counter clockwise 45 deg and remove
adjacent to selector knob shaft is 1/8inch nut, turn clockwise to raise water level counter-clockwise to lower water level, test, adjust, test adjust ~1/2chance of fixing it
If fail
replace level selector body
May 17, 2008 | Kenmore 22422 Top Load Washer
119 people viewed this question
 Grubhead
Grubhead
