Panasonic tv troubleshooting
Picture is missing from top 3rd of screen and edge where picture begins looks warped and condensed, like the whole top 3rd is in the warped portion
  • Kim Kramer
    Kim Kramer May 13, 2014
    this is not a projection TV!
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search with the brand name of your device at its search box.
Posted on May 13, 2014
De Engineer
  • 247 Answers
SOURCE: tube tv problem with picture
There should be controls for height and linearity. They may be labeled as Vertical, Hold or Size.
Hope this helps. :)
Posted on Mar 30, 2008
SOURCE: panasonic pt51sx60a ,bottom of picture
my tv is panasonic pt-51hx41e hay can see picture but come on disturtion in tv ,they side that is mother board $380.00 hay need to now is true,or hay can buy part and ware?
Posted on Nov 18, 2008
  • 147 Answers
SOURCE: 52 inch tv has a warped picture with a rainbow type ark at top
This set needs a major repair. there are bad connections on the power board and a fuse is blown. You pretty much need a technician to fix this.
Posted on Mar 30, 2009
localwonder
  • 6784 Answers
SOURCE: rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
Posted on May 23, 2009
SD Tech
  • 14553 Answers
SOURCE: picture is warped (three colors diverge at edges
WS-55857 uses two STK-392-570 convergence IC's----you may have bad solder connections on them but what is more likely(I have seen this in sets that Mitsubishi made that use this chip) is that some of the pins are broken loose inside one or both of the chips.
Considering the labor to get the board out to resolder it, might as well just replace BOTH of the chips------Usually this repair can be done right in your home and takes about an hour.
If you are able to do it yourself you can buy both chips for less than 15 dollars on Ebay; if you need help I have complete step by step instructions for this repair that tells what you need and how to do the repair---if interested I can email them to you.
If you are not able to do the repair most shops charge 300-400 for this kind of repair; look in your area and if they say "needs to go to shop" keep looking; any good tech can do this repair right in your home.
Now is the slow time of year for TV repair shops so look around--I do this kind of repair here for 200-250 depending on the set --right in someones home! I have done hundreds of these sets.
If you need any help or would like the instructions reply to this comment here.
I do this for free here so if it helped you take a minute and give me a vote here.
SD TECH
Posted on Sep 02, 2009
Picture looks like it is warped at the bottom and top of the picture. Have picture, no problem there, just not a centered picture anymore. Looks like the top of a half moon on the top and botom.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Dec 28, 2010 | RCA HD52W59 HDTV Projection Television
Warpped TV picture
There are two problems here but may be caused by one component
The flyback transformer or transistor equivalent is faulty The colors are warped convergence controls which may be due to a faulty sustain board or part of the first problem. DIY is not an option and repair estimate is about $3-400.00
Please rate my help++++Thanks for uyisng FIXYA
May 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Picture is wavy and double vision
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 06, 2010 | Hitachi 46F500 46" Rear Projection...
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
My picture is warped or bending in the middle
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
Rear projection - convex distortion / ghosting / expanding screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Panasonic PT-47WX49 47" Rear Projection...
White dashes across top left of TV screen
That is what I was going yo suggest. You can also adjust the picture size. "Just" will show all of the picture even the distortions on the edges. "Full" will in effect overscan and trim those edges off.
Apr 27, 2009 | Panasonic SC-DT100 System
Ghosting or distortion on edges of screen
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 26, 2009 | Hitachi 43F300 43" Rear Projection...
Panasonic PT-60LC14 Convergence Issue
*Screen Looks 3-D
*Colors wont align
Nov 06, 2008 | Panasonic PT-60LC14 60" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
