Question about Standard Motor Products Chevrolet Corvette AC125 Idle Air Control Valv
Where do you find the idle air control on a 2000 corvette?
94 corvette rough idle new plugs and fuel filter no check engine light
Dirty injectors maybe , or throttle plate carboned up , IAC - idle air control problem , EGR valve carboned up . Could be a number of thing's . Hooking up a scan tool an checking engine sensor data may point to the problem .
Nov 09, 2017 | Cars & Trucks
Why does my ford taurus idle high code P1506
The code is for the idle air control valve which controls idle speed.
The problem could be a faulty control valve, or a vac leak which is letting in air to the intake and bypassing the control valve.
Jan 19, 2013 | 2000 Ford Taurus
My corvette shut down when i remove the feet from the gas pedal
sound like vacuum leak check replace all old vacuum hoses replace pcv make sure its getting vacuum.make sure spark plugs and wires been replaced.replace fuel filter and air filter clean fuel injectors.code scan for faulty idle air control valve.but do a little tune up see if that helps.most time if i have problems with vechicle i do a tune up make sure engine getting good airflow.plenty of fuel and good spark.i will do a three stage trouble shooting before i find something major wrong with engine.
Nov 17, 2012 | 1991 Chevrolet Corvette
2000 Mercury Mountaineer 5.0L engine. idle speed speeds up and slows down. Idles too fast.
dirty or bad idle air control valve i would at worst the egr valve but most likely the idle air control valve which controls the air and idle from the throttle body try taking it out and cleaning the tip as well as in the throttle body where the control valve goes in if that dosent work replace it and the check engine light does not have to be on for it to be bad.good luck to you.
10 year ford tech here.
Aug 26, 2011 | 2000 Mercury Mountaineer
I need ti install a air pump on a 2000 corvette. Do you have a break down of what needs to be removed to get to the part
  1. Raise the vehicle.
  2. Remove the left hand side lower close-out panel.
  3. Remove the hoses from the AIR pump.
  4. Disconnect the electrical connector from the AIR pump.
  5. Remove the AIR pump mounting bolts from the bracket.
  6. Remove the AIR pump.
Sep 05, 2009 | 2000 Chevrolet Corvette
I have a 1992 corvette with a LT1 and only after the tempature gets to the half way point it smells like fuel and the idle fluctates and some times stalls when i come to a stop I have replaced the idle...
No...Inside the bore of the unit (where the air flows through), you will find two thin wires. In operation, those wires become hot changing their electrical resistance ...when dirt accumulates on them it serves as insulation. (they depend on air flow cooling them off to obtain a reading...more flow = more cooling and therefore different resistance value) To clean them use a Q-tip and carb cleaner and carefully wipe off any dirt. If cleaning does not help, there are tests you can do to check it (they can actually fail, aside from just becoming fouled.)
Sep 05, 2009 | 1992 Chevrolet Corvette
1989 Corvette starting and idle problems
replace the coolant temp sensor, not the coolant temp sending unit
Jun 05, 2009 | 1989 Chevrolet Corvette
1994 Corvette
sounds like a sticky idle air control valve
Sep 11, 2008 | 1994 Chevrolet Corvette
Standard Motor Products Chevrolet Corvette AC125 Idle Air Control Valv Logo
43 people viewed this question
Top Standard Motor Products Electronics - Others Experts
Are you a Standard Motor Products Electronics - Other Expert? Answer questions, earn points and help others
