Question about Thermador PRG364GLUS Gas Kitchen Range
Where is on thermador prg364glus seemer control
  • 641 Answers
Since I purchased my home the grill on my thermadore range does not work. When I move the knobs nothing happens, no clicking, no smell of gas. model PRG364GLUS.
Sometimes the orifice is clogged by a spidermite nest, or cooking grease. If you're confident with this sort of thing, remove the griddle/grill and the burner. Close to the valve there's a small brass piece that you have to remove and clean. DO NOT use a drill to clean it. Count the number of turns it takes to remove and re-install the same number of turns.
Nov 02, 2017 | Kitchen Ranges
Gas oven does not heat up
what is your model number is then we can get started then
Jan 04, 2013 | Thermador PRG364GLUS Gas Kitchen Range
How do i gain access to replace spark moduek on thermadore prg364glus...thank you
go youtube you will see spark module in short video undo two burners in left side of range
Sep 08, 2011 | Thermador PRG364GLUS Gas Kitchen Range
Is there a tool to remove the nut for burners
Yes it takes a special tool. Try www.appliancehelponline.com or go directly to the thermador site and request one. They are inexpensive.
Apr 08, 2010 | Thermador PRG364GLUS Gas Kitchen Range
How do I put the oven door back on, it was accidently pulled off and the manual does not show how to put it back on. We can't figure it out. The manual had only one small picture showing parts nothing...
We did fix our problem the the Thermadore. Someone accidentally pulled the door off trying to pull it out from the wall during a remodel at our church. We couldn't figure out how to get it back on but i found the info i was needing. It is now fixed but thank you for your time..
Jan 08, 2010 | Thermador PRG364GLUS Gas Kitchen Range
I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
The bottom heating element is not working on my thermador prgs/36
one of 3 things may of happed. 1, the element may have burned out. (you will see a blister or burn through on surface of element. 2 the wires that go to the element may have burned off. 3 the power relay board is not sending power to the element. (bad board or fans sail switch NG)All things need to be checked with 220v power off to the range. I would recomend calling a local pro.
Oct 30, 2009 | Thermador PRG364GLUS Gas Kitchen Range
Thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Thermador PRG364GLUS Gas Kitchen Range Logo
Top Thermador Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
