Question about GE GSL25JFPBS Side by Side Refrigerator
GE refrigerator model gsl25jfpa bs not working all of a sudden, it stop
MNTECH
  • 1543 Answers
SOURCE: not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Posted on Aug 28, 2008
  • 126 Answers
SOURCE: I don't seem to have
First thing to do is change the water filter let me know if that doesn't work I'll tell you how to unfreeze the resevoir.
Posted on Jan 16, 2009
  • 12 Answers
SOURCE: the water in the in-door dispenser is coming out hot
If this freezer is like most, the water going to the dispenser is looped around many times in the refrigerator section near the back. Make sure that this is still true. It must have a lot of water cable in the refrigerator section so that the water has time to cool down before it goes out the dispensor. If for some reason the water tube is touching either the compressor motor or another hot part of the external refrigerator it could cause it to be to hot to cool down in time during its travel through the refrigerator as well as it will start to warm up the refrigerator section as well.
Also, I am sure you have tested, but make sure that you are plugged into the cold water supply and not the hot water supply. Check the water at the connector and see what the temp is at that point before it enters the refrigerator.
My guess is that the coil of water tubing that is usually in the back of the refrigerator section has been either lessend in length or the water entering the refrigerator is too hot to be cooled down in time before it reaches the dispenser.
hth
Posted on Feb 19, 2009
aasc
  • 1606 Answers
SOURCE: where is the thermostat on a GE profile refrigerator Side-by-Side
There is no thermostat ( cold control ) on your model refrigerator . It works off thermistors ( 3 in the refrig section and 2 in the freezer section ) . These thermistors , operate by the coldness which in turn , less resistance to the main control board the colder or warmer it will provide .
Posted on Sep 12, 2009
aasc
  • 1606 Answers
SOURCE: GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Posted on Aug 16, 2012
I have a GE side by side refrigerator, model #gsl25jfpa, that will not stop frosting up. I have replaced the motherboard, the little thing that attaches to the tube to determine frost, temperature sensor...
Michael, you probably have a bad thermistor. Based on your model number there are 3 thermistors in your unit. Since yoy already have done so much I would just replace all of yhem. The thermistors only cost about $8 to $10 and are easy to replace. Hope this helps.
Oct 18, 2013 | GE Profile PSW26P Stainless Steel Side by...
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Problem with my GE refrigerator model # GSL25JFPA BS freezer nor frig gets cold but there is still electric to it
check the gaskets on the doors to see if they r sealin proplerly if they r than that means that it is low on freon and it is cheaper to buy another refridgerator.
Aug 23, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Aug 14, 2012 | GE Refrigerators
I have a GSL25JFPA BS that the frig side will not cool properly. Repalced the mother board. t stat in freezer and thermistor in frig. Freezer works fine. Damper will open when first plugged in but closes...
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Jul 06, 2011 | GE GSL25JFPBS Side by Side Refrigerator
MY GE GSL25JFPA-BS SIDE BY SIDE REFRIDGERATORS FREEZER TOP PORTION IS NOT COOLING
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 09, 2011 | GE GSH25JFR Side by Side Refrigerator
My Fridge GE Mod# GSL25JFPA BS, does not dispense any water, I have replaced a bad water celinoide, I blow into the 1/4" tube and it seems to be cloged from the door to the dispenser on the door. is...
g.e. has had problems with the freezer door.when the foam is blown into the door if the water line doesn't get covered the line freezes.you can call them and tell them your problme,i've seen them send out a new door for free.also g.e. has a heater kit made for this problem part number WR49X10173 and it's around 30 dollars
Feb 15, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Gsl25jfpa bs fridge is warm on top and frozen on bottom and freezer is warm
It sounds like the fan in the freezer is not working , to circulate air , and the coldness is just dropping . This will cause the icemaker to stop working first , then the top portion of the refrig next . As this coldness drops , the lower portion of the fridge ( crispers ) , will freeze . The main control board , causes the fan , not to run . Part Number WR55X10656 . The main control board , is located , behind the refrig , behind an 8 " X 10 " , small panel . There is usually a burnt resistor on the board , which is connected to the fan . Unfortunantly , the whole board will need to be replaced . It is easily replaceable . Doesn't take any special knowledge . All the plugs 6 or 7 , each fit the pin plug designed for it .
Oct 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
The water in the in-door dispenser is coming out hot
hth
Feb 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
83 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
