Question about Raindrip R673CT Digital Water Timer
How to program the unit. i received no instructions when i purchased it
Instruction on how to program it
Help I can't programme my elero prp433 Shutter door control unit
Hi Kristian - I have the same control box/receiver and have lost my remotes.
I tried to buy a non-branded remote to program, but they are not compatible with Elero receivers.
During my search I found these instructions which might help you:
http://www.elero.com/downloads/English_UK-Worldwide/Instructions/Controls/OptiLite_Surface-mount-receiver_instructions_(GB-Stand_01_08).pdf
Perhaps you could help me? I am looking to connect a new receiver box (which you can get for 35 GBP including 2 new controls) to get around my problem. The issue I'm having is knowing which terminals on the receiver unit's circuit board I am connecting the external receiver box to.
Do you have any instructions at all for your receiver/control unit? If not, would you be so kind as to take off the cover (just undo the 4 screws in each corner) and take some close-up photos of the terminals (see my picture here as an example www.eugenereisch.com/prp433r04e.jpg
I would be extremely grateful!
Aug 06, 2013 | Televison & Video
I HAVE PURCHASED NERO 8 BUT I HAVE NOT RECEIVED ANY DOWNLOAD INSTRUCTIONS FROM THE PROVIDER. PLEASE HELP. THANK YOU
Hello, where have your purchased the nero? nero can be downloaded from nero website I can give you a link, did you receaver a serial number for the program?
Sep 11, 2008 | Computers & Internet
I need the code on a paramax audio receiver p-701 for a universal remote.
Hi, you need to refer to you instructions book that came with your RCA remote when you purchased it new. It will have all the codes and instructions on how to program the remote inside the book. But all said and done, even if you find your original manual for your RCA remote and programmed it. It will probably still not work because RCA universal remotes arn't made very well to be compatible to receivers.
I suggest getting your original remote if it is still available. Try going to Replacement Remotes, as they have most all original remotes available and you will not have to program an original remote from them. Search for your model of receiver in their search box.
Oct 08, 2012 | Televison & Video
My motorola RDU2020 radio receives but does not transmit calls
1) You possibly have a bad or nearly dead battery. Transmit takes more energy than receiving. With this in mind, your radio's transmit will fail, if you have a poorly charged or bad battery, when pressing the PTT. Try a battery from a known good radio to see if it eliminates the problem. If so, replace your battery.
2) The radio is either programmed incorrectly or in need of repair. If you have been experimenting with the programmable features, we suggest you walk back through the steps of programming. Here is a link to the user guide: http://www.mytoolstore.com/motorola/rdx_userguide.pdf Programming instructions begin on page 36.
3) If in need of repair. Radios less than one year old should be under warranty, barring any physical or water damage to the unit. Contact the place of purchase or Motorola for warranty instructions.
If the radio is more than one year old you can get it repaired at any dealer offering Motorola repair. (approx. $85 flat rate)
Best regards.
Jan 12, 2011 | Motorola RDU2020 Two Way Radio
Need manual to program remote to a different frequency
Each fan with have a receiver unit mounted in the housing, usually above the fan up against the ceiling. Each receiver unit will have 4 "dip pins" which allow the code to the remote to be set. In order for two fans originally installed with the same code to be run separately, one fan will have to be taken down, and the code changed on the receiver unit. Then you will have to purchase a new remote and set the same code on its dip pins (usually under the battery.) It's easiest to buy a replacement remote WITH a receiver AND a transmitter in it. You can either wire in the new receiver (setting the code differently than the existing one on BOTH the receiver AND the transmitter) OR just put the receiver aside and program the new code that you've set in the old one into the transmitter.
Apr 25, 2009 | Universal Remote Control Hampton Bay...
Change the code on a garage door transmitter?
There is a "learn" button on the garage door opener unit itself that you press before entering a code on the outside transmitter. This allows the receiver to learn a new code. The button is on the rear end of the housing near the terminals where the inside operation pushbutton connects.
Here's a link to programming instructions for a compatible unit by another manufacturer:
http://www.usdoorcontrol.com/instructions/liftmaster/keypads-66LM.pdf
Nov 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
I purchased a Panasonic DMR-EZ48VK and connected it per instructions. I was able to do the Intitial Setup,and program the Remote to recognize the TV, but now I can NOT get the Remote Programed! I follow...
The remote lost connection with DVD set. Push OK and hold while you Push #1. This will reset the remote. Connection instructions with set are wrong! After re-wiring, everything works great! I had to call Panasonic and sit on hold, but they were very nice.
Sep 30, 2008 | Panasonic Televison & Video
Tomtom One
If you have the programs downloaded from tomtom home then you need to copy them to the sd card that you purchased. In the home program you can choose to install the programs and map to the sd card. It takes a bit of a search to get the tomtom home program understood. The credit card with the codes is an authorization code for the program.
May 17, 2007 | Tomtom 1D00.081 GPS Receiver
Raindrip R673CT Digital Water Timer Logo
114 people viewed this question
Top Raindrip Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Hippy_dd
Are you a Raindrip Hardware and Accessory Expert? Answer questions, earn points and help others
