Question about Canon imageRUNNER 210S Copier
Canon image runner can't close door on right side
  • 11 Answers
SOURCE: Canon Image runner photocopier
error comes two types. first spares error.second normal error.first see disply which error comes.first clear all error. <* 2&8 * ><copier><function><clear><err><o k>then machine off and on maximum all errors cleared.
Posted on Oct 01, 2008
color_50
  • 22 Answers
SOURCE: ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Posted on Mar 14, 2009
canontech
  • 1219 Answers
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Posted on Jul 25, 2010
Testimonial: "so thanks"
SOURCE: I have a Canon Color Image Runner C5180. When i
how to ip adres inetall
Posted on Sep 08, 2010
kuldeep_sudh
SOURCE: image runner 4570
i m kuldeep i have 2830 canon plz tell me about the e000100-0001 hurry
Posted on Feb 03, 2012
HOW TO LOAD STAPLES IN A CANON IMAGE RUNNER 3025
pull the finisher assembly out by the handle located just below the finisher output tray.on the back side of the finisher u will find the stapler unit.reload them by simply taking it out and then close the finisher
Jun 03, 2011 | Canon ImageRunner 3025 Black and White...
My canon image runner 3235i will not power "on"
on back side of the copier are small black switch, it is protective fuse. Try to put him back ON.
If these doesn't helps you have power supply problem....
Keep me posted!
Hope that helps!
Apr 19, 2011 | Canon Image Runner 3320I Copier
HOW DO I PRINT AN ENVELOPE ON THE IMAGE RUNNER 3025
On right sideway of machine is door, on this door is bypass tray wich you need to open.Open and place envelopes on it, use paper side guidances, envelope must be print side face down.
"Tell" the machine wich is format, type and confirm.
Under printer driver set according settings.
May 14, 2010 | Canon ImageRunner 3025 Black and White...
I have a Canon Image Writer 2020. I am geting an
waste toner is full.replace the whole drum unit
Mar 03, 2010 | Canon imageRUNNER 2000 Copier
I have a cannon image runner 2000. When i turn it on it says check printer cover. What do I do
It probably has a fragment of paper in it somewhere. Get a can of compressed air and blow it out. The open and close every door there is.
Feb 18, 2010 | Canon ImageRunner 1600 Copier
Remove a paper jam under the fuser unit on a canon image runner 5070
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
Aug 17, 2009 | Canon imageRUNNER 5000 Copier
Waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
May 26, 2009 | Canon imageRUNNER C3170U Color Copier
Error code e000800-001
not the fan open the front door pull out number one unit check the assymbly behind the frame it will move when you move the handle if its bent tou will get that code when you close the door
Nov 08, 2008 | Canon imageRUNNER C6800 Copier
Canon imageRUNNER 210S Copier Logo
old marine
old marine
