Question about Minolta Maxxum 500si 35mm SLR Camera
Help Displaying in LCD
Hi, has anyone else had the problem of "help" appearing in the LCD when depressing the shutter release? If so, were you able to resolve the problem?
Many thanks for any support.
0 characters
1 Points
N65 shutter button failure
Follow this link: Nikon N65 Camera Body 35mm SLR. You can buy a working replacement body for $19.99. A camera repair man will charge you three to five times the replacement cost.
Jul 04, 2012 | Nikon N65 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Hi i have a Vivitar film camera, V3800N I lost my handbooks and i dont know which knob or dial is the one to adjust the shutter speed.... can anyone help me?
The big knob with all the numbers next to the shutter release.
You can download a manual from
Oct 03, 2010 | Vivitar V3800N 35mm SLR Camera
How do set the self timer in Nikon F70
Press the SET/timer button (top left of the camera, behind the FUNCTION button, marked SET with a one-handed clock icon) and confirm that the one-handed clock begins blinking on the LCD panel. While pressing the SET/timer button, rotate the command dial one click to stop it blinking. Proceed normally (frame and compose picture, half-press shutter release button to meter and autofocus, etc). Fully depress the shutter release button to take the picture after a ten-second delay.
If you need a manual, you can download one from . Look for "N70", which was the name used in the USA.
Apr 29, 2010 | Nikon 35mm SLR Cameras
Have a canon rebel EOS 20D that registers an error 99 after I take one frame and then won't allow another one to be taken until I turn camera on then off again. Does this require factory repair or is there...
Hi LLFraserny,
You can probably try to isolate the error 99 first.
To isolate the cause of the issue, do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 30 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera will need to be serviced. If the message does not appear, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
One last item to check before sending camera to Canon service is the alignment of the shutter. Life the mirror and visually inspect the shutter curtain. If each segment is not completely straight, touch it lightly with your blower bristles and try to pop it back into alignment.
Hope this helps,
Apr 09, 2010 | Canon 35mm SLR Cameras
35mm slr praktica bca shutter problem.
1) Open the top cover.
2) On the film advance gear, the shutter winding lever is attached to it.
It has screw adjustment there. Unscrew the screw ( not all the way out ) You will need to adjust the wind travel and make the length of the wind lever ( made of spring steel) shorter and tighten the screw.
Mar 06, 2010 | 35mm SLR Cameras
After taking a picture, I get only about a fourth of the image to appear. I tried changing the lens, changing the flash card, but no success
There is either something obstructing the image sensor, or the image sensor if defective. Take off the lens, set the camera to manual mode, select 'bulb' as the shutter speed, then depress and hold the shutter release button. Look inside, what do you see?
Jan 29, 2010 | Canon EOS Rebel 2000 35mm SLR Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Manual Exposure mode Nikon F80
1) turn the mode switch/knob on the left of the camera to M ( manual mode ) 2) turn your lens to the highest f-stop ( 22 or 16 depending on your lens ) 3) in front of shutter release button you have control for your aperture : turn until the desired aperture is displayed ( view finder or the LCD monitor on the top ) 4) your shutter speed setting is controlled with your thumb with the control situated next to the strap lug on the right hand side of the camera. 5) press shutter release half way and look through viewfinder and see light meter reading and adjust either shutter speeds or the aperture as explained being guided by the l.meter.
Sep 23, 2007 | Nikon F80D 35mm SLR Camera
Minolta Maxxum 500si 35mm SLR Camera Logo
20 people viewed this question
Top Minolta 35mm SLR Cameras Experts
Mark Schmit
Mark Schmit
Are you a Minolta 35mm SLR Camera Expert? Answer questions, earn points and help others
