Question about Samsung Televison & Video
Samsung ln-t669f intermittent shadowing on the left side of the screen, causing the screen to look darker than normal
    Top Expert:
  • Samsung Master
  • 74,383 Answers
Sounds like a back-light problem. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search with the brand name of your device at its search box.
Posted on May 13, 2014
lukster
  • 217 Answers
SOURCE: Green shadowing on Samsung LN-S3251D
sounds like you need a service call if it's in warranty, if not in warranty, you may need to have the logic main board replaced
Posted on Apr 30, 2007
jhinsincity
  • 616 Answers
SOURCE: Our Vizio TV has a shadow on the left side of the screen
sounds like a bad panel, not repairable
Posted on Dec 10, 2009
  • 16 Answers
SOURCE: 2 year old Samsung LN-T4661F has irregular shaped
most likely it is a separation of the layers of the lcd screen
Posted on Feb 06, 2010
  • 122 Answers
SOURCE: LN-R408D Samsung LCD flat screen TV
they must try to repair the smps [puff capacitors]first.then try a master reset thru the service mode.if these steps do mot solve the problem replace the t-con board on lcd panel.
Posted on Mar 09, 2010
SOURCE: When I trun on TV (Samsung LN-T4661F 46 In), it
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Posted on Jun 29, 2010
Samsung vertical shadow screen
Does the screen have a double image? or is one side of the screen darker and has a delay? If so, your LCD panel is failing, common problem with older Samsung LCD's. I have the same model in my dining room that had a double image, fixed it by taking the panel apart and applying thermal pads on top of the panel tabs. The set works like a champ to this day!!!
Oct 27, 2013 | Samsung LN-T4665F 46 in. LCD Television
Samsung Ln-T4671F screen is getting darker. The whole screen is darker, not only the right or the left. Also a red vertical line appeared about a year ago, haven't noticed since- don't know of its...
MOST LIKELY YOU HAVE A DEFECTIVE LCD PANEL. Try lightly squeezing the top of the TV. Start from one corner and work your way slowly to the other side. If squeezing the top of the frame clears up the screen problem, you have a defective LCD panel tab. The only true repair is the replace the screen. This cost for a replacement panel could cost more than a new TV set.
Sep 03, 2012 | Televison & Video
Samsung tv getting darker
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Aug 26, 2012 | Samsung Televison & Video
Samung LN-T4061F - Dim Picture
Does it look like a dim black swirling cloud with very faint images?
Mar 24, 2012 | Samsung LN-T4061F 40 in. LCD HDTV
Hello. My Samsung LCD model # LN-T3253H 60"/61"
It sounds like your LCD panel or your T-con board is bad . Panels are expensive so I would replace the T-con board first. You have to open the TV and get the part number from the actual board in order to find the correct one. You can find parts at www.interliquidparts.com
Jun 03, 2011 | Samsung LN-T3253H 32 in. LCD Television
I get an intermittent shadow on the left-side of myscreen. Computer works fine, except at times I have the shadow.
If you mean that the left side of the screen goes darker than the right side, then this is an indication of a faulty backlight. There are probably two CCFL tubes, one on each side of the screen. If one starts to fail, then that side of the screen will get less light and look darker. The tube may need to be replaced.
May 25, 2011 | Acer Aspire One PC Notebook
Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Dec 15, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
May 25, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Henry  Thomas
Henry Thomas
