Question about Samsung WB210 Digital Camera
Take a photo but sometimes get file error message and photo isn't captured on memory card?
5 Suggested Answers
informatica
  • 1114 Answers
SOURCE: samsung s630 "file error"
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off)and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems. If you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link: http://www.cgsecurity.org/wiki/PhotoRec If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many. One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below: http://www.lc-tech.com/software/rescuepr... You can try the demo to see what you can recover before buying. Remember - Do NOT try & write anything back to the card until you can recovered your pictures to your PC safely! Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 28, 2007
SOURCE: memory
I think you go to menu, then go to the lat tab and then click format, then yes.
idk ? HAHA i thinks thats how it is.
Posted on Nov 29, 2008
smilemaker
  • 790 Answers
SOURCE: whenever i take a picture and press to review it says file error
Hello!!
Try formatting ur memory card once and reload it ...
Posted on Apr 20, 2009
  • 11967 Answers
SOURCE: losing photos
They are probably still there. Get yourself a card reader and use it to download your pics. f1eb652.jpg
Posted on Jul 06, 2010
Pdr m700
Hi Lorinda,
There are a few different reasons why your camera may not be reading the memory card.
Troubleshooting such problems can be a little tricky, especially if no error message appears on your camera's screen.
The cause and solution may include one of the following:
    ·The card may not be the right type for the camera: First make sure the memory card you are using is compatible with your camera. For example, a SDHC memory card often will not work with older memory card readers. Even though SD memory cards are similar in size and shape to SDHC cards, they use different software for managing the card's data, meaning older readers sometimes cannot recognize the SDHC cards. Sometimes you can solve this issue by updating the memory card reader's firmware to give it the ability to deal with SDHC cards. Check the Web site of the manufacturer for your memory card reader to see if new firmware is available. It is also a good idea to check with your camera's manufacturer (on it's website) to see if an updated version of your camera's firmware is available.
    ·The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    ·The card or a file on the card may be corrupt. Photo file corruption can occur when the battery power is too low when writing a photo file to the card, or when the memory card is removed while the camera is writing a photo file to the card. One way to check if it is the card or your camera is to try moving the memory card to a computer, then try accessing the photo file directly from the computer to see if the file actually is corrupted, or if your camera is just unable to read a particular file.
    You can also double check this issue by using another memory card in your camera and see if it works as it should. If the memory card is unreadable on any device, the next step is to reformat the memory card. Look through your camera's on-screen menus to find a "format memory card" command. However, keep in mind that formatting the card will erase all photo files stored on it. Some cameras just work better with a memory card when that memory card is formatted inside the camera. If you do reformat the card, make sure to let the process finish itself before removing the card. Removing a card during formatting may damage the card.
May 01, 2014 | Toshiba PDR-3300 Digital Camera
Unable to delete the files from memory card
take out ur memory card from mobile slot, make unlock ur memorycard adapter. its on the side of it. and insert it and try deleting folder.
Oct 18, 2012 | Motorola Mobility ROKR E6 Smartphone
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
I have a Fujifilm finepix camera and my fujifilm XD card has a read error and won't show my pictures on the camera or in a card reader. Are there any free recovery programs out there?
Sometimes memory card error happens without any notice. But luckily most of the time we are able to fix the memory card error and get back files on the memory card. Take a look at this guide:
Fix memory card error and recover data
good luck!
Jul 20, 2009 | Fuji FinePix A360 Digital Camera
Whenever i take a picture and press to review it says file error
Hello!!
Apr 20, 2009 | Samsung Digimax S630 Digital Camera
File errors, distorted photos.. I hate the Samsung L100!!
regarding the use, you have to check if you are using the right memory card for your camera.
you can only use 2GB sd card or 4gb sdhc card.
try this and if you still have an error message. you better send the camera for service.
Jan 19, 2009 | Samsung L100 Digital Camera
Cannot copy files (music, photo etc) from int memory to memory card
i'm having the same problem. can't transfer files onto memory card. when i try, it says "no entry". someone please help.
Jan 03, 2008 | Samsung SGH-D820 Cellular Phone
Error message: card cover open..yeah right
Hmmm, I'm thinkin' if there's no memory card in camera, there are NO memories, aka formerly known as photos. Unless there is some sort of an internal memory, but me thinks not. As for error message, might be because....card fell out while an image was being captured.
Apr 28, 2007 | Olympus FE-130 Digital Camera
"Read only card, change to internal memory to capture"
This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Samsung WB210 Digital Camera Logo
14 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
