Question about Cuisinart GG2PR
Looking for plug that goes into the griddle - Cuisinart GG2PR
I have a Viking Professional VGRT Gas 4 Burner + Griddle Cooktop. The griddle stopped working all together. The burners still all ignite and work fine. The griddle does not heat up. When we turn the...
I just had a tech come to my house and he told me that I need a new glow plug, It's the box to the right of the flame. Looks easy to replace, his visit took 5 minutes and it cost me 143.95 (this doesn't include the cost for the part or to have him come fix it, that will be sometime next week) so if you can get the part and do it yourself I would suggest that.
Jul 29, 2010 | Microwave Ovens
I am looking for a replacment part for a 3 year old General Electric Gas Stove. The part I want is the grill that goes on top of the cooktop between the burner, whis is used for cooking items such as...
Your looking for the griddle.
I am not sure if this is the exact part your looking for due to the model number listed in your post does not have one as a parts replacement. If you have a good model number I can probably find a source for the part.
Here is one GE griddle:
http://www.appliancepartspros.com/Appliance-Parts/GE-Griddle-item-number-AP3205515.aspx
If this is not what you were l;ooking for please provide a model number so I can better help you.
Thanks for using FixYa!
Kelly
(it may not be the one for your range but it is one of 2 types they used)
May 18, 2010 | GE Adora JBP77SMSS Stainless Steel Kitchen...
Need replacement cord for WP's cafe collection reversable griddle
I need a D.G. King Way PO-0800 Plug for Model No. CCRG0030 ,
for Cafe Collection Reversible Grill and Griddle. Do you have one and how much is it?
Feb 28, 2010 | Wolfgang Puck Reversible Grill and Griddle
I was given a 36" magic chef gas cooktop with griddle. It was very greasy and dirty, all the burners were sticky and slow to get turned on, but 2 of them refuse to turn on, parts lists say the griddle...
If it's two burners on the same side that won't light, it is probably the igniter for that side. If so, remove the grates, griddle, and griddle sub pan, and then lift up the main "pan (if it's like mine, it's hinged at the back and lifts up). Now, if each burner on that side has a tube going to the middle between the burners, the igniter is in that middle section. Mine is a small plug-in ceramic and metal part (see photo). If yours looks like this, contact me at jazzskier@verizon.net, I have a spare.
Nov 29, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Plug in cord for Presto electric griddle model #7032
you can find them on amazon. take a look Amazon com Presto electric griddle parts (note: watch out on sellers rating) Hope this was helpful. regards
Mar 27, 2009 | Presto 07034 Electric Skillet
Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
NEED PLUG IN FOR MODEL# CCRG0030
I saw one on ebay today, 8/01/09, while looking for a handle. If I don't find a handle you can have mine.
Mar 03, 2009 | Wolfgang Puck Reversible Grill and Griddle
I have a viking cooktop with 4 burners and a center griddle. The griddle will not hold heat. It fires up then goes out.
This can be cause dby one of 2 problems.
When you turn the control to turn the Griddle on, does it come immediately or do you have to turn it a long way before it comes on?
If it turns on immediatly then it is more than likely the Ignitor
If you have to turn it a long way you have a defective Thermostat
Feb 18, 2009 | Viking VGRT600-6G Gas Cooktop
Cuisinart GG2PR Logo
112 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
