Question about Dyson DC21 Bagless Canister Cyclonic Vacuum
I loose suction by the power recoil - Dyson DC21 Bagless Canister Cyclonic Vacuum
  • 23 Answers
Check hoses, maybe clogged up
Posted on May 13, 2014
My Dyson works perfectly well with the base plate. As soon as i use the hose part it tends to loose all power and i cant even stretch the hose properlu
The hose is blocked, so you have very little suction at the end. The vacuum in the hose is pulling the hose shorter. With the vacuum turned off, push a broom handle through the hose to dislodge the blockage.
May 11, 2016 | Dyson DC40 Multi-floor Vacuum DC40
How do I deassemble the vaccum to see power cord assembly area to see if power comes to taht point
You don't, you take it to the shop and they fix it for you under warranty. And it's dangerous to play with power.
Feb 04, 2018 | Eureka Vacuums
Dyson dc17 No suction
i have the same problem and none of these solutions help. they are all for if suction works but brush doesn't. that isn't what she is saying. brush motor works fine. It's the Suction motor that never kicks on. Mine is doing it now and I would love a fix for it. Resetting suction motor. Not brush....
Jan 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
When the dyson is in the upright position it goes off and I cannot use the wand . . . I have cleaned the filter and nothing is stuck in the hose but the wand has no suction power. HELP! I love my DYSON! ...
Here is something to try. Follow the hose down to where it snaps into the main base. My hose has come loose a couple times. There should be to clips that you can pinch to remove the hose. Make sure it is fully snapped in.
When you remove the hose, is there suction coming through that rectangular hole?
Jun 28, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Having a loss of suction issue. Has some suction but isn't enough to use the power head. Tried to take out the filter to wash it but the pull loop ripped off. How do I get the filter out now without...
You should be able to get a screwdriver or tool under the ring to be able to get ahold of enough to pull it out. Check the suction (a suction gage helps) at the power unit and then at all inlet valves. It could be a leak or clog somewhere in there. You have to check all areas to try to narrow down the problem. Look for a loose hose, tube, valve, fitting etc. Check Vac pans closely if you have them.
Feb 13, 2018 | Beam Industries 2900 Serenity Plus Central...
Hoover turbo power 3100 is loosing suction
The suction that is lost is usually from a plugged up inlet to the filter bag. Check all areas the debries go through for you will find a spot clogged up especially at the bends were it catches all the time causing this problem
Apr 10, 2010 | Vacuums
Not alot of suction but when using the hose alot of suction is it a motor problem how do i fix it plz bagless up rite
It could be your belt, if it is loose it will not turn the roter at its max power which means less suction.
Mar 11, 2010 | Dyson DCO3 Absolute Bagless Upright...
EF 1750 has lost suction power. There is a noticable decrease in suction power even at the power unit inlet.
Disconnect the actual pipe where it meets the vac. Then test the intake for suction. If you have poor suction still, check the intake itself from inside the vac body for blockage, then check the gasket on the pail for mis-alignement.
If you have suction at the actual intake, your issue will be in the house piping. Look for any damaged inlet doors which are ajar, also look at any inlets you may have recently removed for painting or renovation work. Each inlet has an o ring seal which must be properly aligned. If not aligned you will hear a hiss at the inlet when the door is closed.
Last check where any exposed pipe or pipe joint could have been jarred loose or damaged, basement , garage, etc. Post back to advise what you find
Nov 06, 2009 | Easy Flo EF1750 Central System Vacuum
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Turns on, brush rotates, but no suction.
the only thing i know about vacs is if there is no suction its blocked might have sucked up a piece of plastic bag and wraped around the fan hence no air or the screw that holds the fan has come loose take your filters out and turn on you may have sucked up fluid and not known it hence filters are blocked also brushes may seem alright but may be worn under half there fore springs are not at right tentsion if your armiture is black where the brushes run on may not be getting a good contact or if it smells burnt good chance you burnt it out then theres the power switch test with multi tester the check for loose terminals then test the field coils are correct ohms as well
Jul 09, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC21 Bagless Canister Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
