Question about Panasonic TY-LA1000 Projector Lamp for PT60LC1
How do i reset the lamp timer on my panasonic tv PT-44LCX65 without a remote
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Posted on Jan 14, 2015
2 Suggested Answers
  • 927 Answers
SOURCE: I have a PT-44LCX65 and replaced lamp accordingly
Howdy,
No, you must have the Remote.
Sorry, big IRISH.
Posted on Jan 02, 2010
PUT IN A NEW LAMP BUT NEED TO KNOW HOW TO RESET TIMER. THE WORDS STAY ON THE SCREEN FOR 1 MINUTE.
Turn the TV on, and once the timer leaves the screen (after 1 minute as you say) you do the following.
Hold both the "Volume Down" button on the TV it's self and the "Split" button on the remote for at least 5 seconds. That should reset the timer.
Jan 21, 2011 | Panasonic PT-44LCX65 Television
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
I replaced the bulb in my tv. pt44lcx65. everytime i turn on the tv it says i need to reset the bulb timer? how is this done? thank you.
Instructions should be with new lamp. Press and hold volume down on TV front while pressing PLAY, or SPLIT, or PIP on PAN TV remote aimed at little window on TV front near front panel buttons for 5 seconds. Message will appear on screen saying lamptime reset. Press end to exit.
May 02, 2010 | Panasonic PT-44LCX65 Television
I just replaced a lamp and don't know how to reset i have a panasonic multimedia projection hdtv model# pt-44lcx65-k/ pt-52lcx65-k/ pt-61lcx65-k. i bought a lamp unit part # pt-52lcx65 for my tv
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know.
If you need further assistance or if this did not help you please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 05, 2009 | Panasonic Televison & Video
MY PANASONIC PT-52LCX35 REMOTE DOES NOT HAVE A SPLIT OR PIP BUTTON. MY BOTTOM BUTTONS ARE TV/VCR, VCR/DBS CH UP,DOWN. HOW DO I RESET THE LAMP TIMER. THIS IS THE REMOTE THAT CAME WITH THE TV.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. The buttons used are the TV's volume down and the remote's number 0, not the 'split' or pip for your model.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Oct 10, 2009 | Panasonic PT-52LCX66 Projection Television
Same problem
You mean physically replace the lamp or reset the lamp timer?
To replace the lamp, you unplug the TV, take the front cover off of the TV under the screen, open the little door, unscrew a screw, then pull a handle that will pull out the entire lamp assembly.
Shove the new lamp assembly in place, reattach the screw, shut the door, snap the panel back on, and fire it up.
To reset the lamp timer you have to have your TV remote (not a universal - the original remote). Turn the TV on and wait for the lamp timer reset message to disappear or push Exit on the remote (or any button similar to exit, depending on the model).
Then, simultaneously press and hold the VOL- button on the TV and the PIP button on the remote at the same time (usually near the bottom left of the remote). On some models it is the SPLIT button instead.
IRT the other answer, there are more than one type of rear projection television. The one's you have seen with three lamps are CRT-based and have one CRT for each primary color of red, green, and blue. Panasonic no longer makes these and any issues with the lamps must be referred to an authorized servicer. Therefore, I conclude in this case that the question is in reference to a DLP or LCD rear projection display.
Aug 22, 2009 | Panasonic PT-44LCX65 Television
How to reset lamp timer
While pressing the VOL- button on the projection display,
hold down the PIP button on the remote control
simultaneously for more than 5 seconds. You will see a screen pop up that says "Lamp time was reset to 0" and the lamp indicator light will go out.
Dec 02, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
90 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
