Question about Apple Ibook G3 12.1" Laptop -a1005 800mhz 256mb 30gb Cd Wireless Lot Of 21pc
Won't power on?
Just purchased on internet, so have nothing to refer to!!
How do I upgrade to commercial free watching?
You would need to contact the service provider. Fixya has nothing to do with that
Feb 01, 2017 | Computers & Internet
I don'tsee what i just purchased. 2 ganes I alredy have won"t run now. on occasioun it tells me i have no connection-not possible Please help me
it is possible,just because you are connected wirelessly,doesn't mean that you are connected to the internet,you ARE ONLY CONNECTED TO YOUR MODEM,unplug your modem from the internet and power for 30 seconds then plug in the internet wire then power and let it reboot,then see how the connection is.if you have more things connected to the modem,either wirelessly(like laptop) or wired(like xbox or tv),they will use your bandwidth which will cause connection errors on a tablet
May 28, 2015 | Tablets & eReaders
How do I get English study material on-line?
Does the software have it's own website where you can either purchase or get free material.
Online is the internet!
Try searching for Nuance English Study. If you find the site and there's nothing about it - ask them.
Feb 06, 2015 | Nuance Communications - 32-A21A-15120 -...
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
My password won't let me in to twoo
if you are referring to a lost internet password ring you ISP internet service provider to get a password reset
hope this helps
Oct 11, 2012 | Computers & Internet
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
When it is powered up nothing works, it won't eject, won't open up, blue light doesn't come on, "no signal" shows up on screen. This is on the Vizio Blu-Ray player. Wireless...
Hey, Firstly make sure all the plugs and cables have been plugged in (Securely) after this turn the power off by the mains then back on. If this does not sort out the problem take it back to the shop and ask the tech support for advise. :)
Jun 12, 2011 | Video Game Consoles & Games
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Apple Ibook G3 12.1" Laptop -a1005 800mhz 256mb 30gb Cd Wireless Lot Of 21pc Logo
70 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
