Question about Dell Inspiron 1300 Notebook
Inspiron dell 1300 has the battery icon flicking yelow color. will not hold charge when connected to charger; however, it works with charger perfectly. Problem?
  • 255 Answers
Your battery has problem and your battery socket connection also have some problem.
Posted on Jun 23, 2009
Dell inspiron n15010
Before looking for a replacement charger, try this:
1. Remove charger from power socket
2. Remove battery
3. Hold the Power On button on the laptop about 10 seconds (while the battery is removed), and release
4. Plug in the charger to the laptop and power socket (without battery)
5. Try to turn on the laptop
Check also that all the cables from the charger are connected firmly.
If this doesn't work, you will need to replace the charger. Take the laptop with you, so you can try the new charger on the spot to be sure.
Jan 13, 2014 | Dell Computers & Internet
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
My dell 1545 inspiron wont operate on the battery works fine on charger and battery icon shows 100% and charging but as soon as power removed laptop immediately powers down. physically measured battery...
I think that if it's 100% it should say that it's fully charged.There could be something wrong there.
My computer blinks with a red icon on the printer saying that the it's recommended the battery be replaced when the battery goes bad. It shows 100% charge as well.
I just got a 9 cell battery off of Ebay for my Acer Aspire that lasts 3 or 4 hours and is a little big, but fits the contacts and locks on.
Jul 19, 2010 | Dell Inspiron 1545 Notebook
For some reason my Dell Inspiron 1525 wont charge!!. I plug it into the main and the green light comes on the charger lead and it is putting power into the computer but just not actully getting any charge...
This only mean that you have a failing battery and does not hold charge anymore.. battery life can last upto 2years, depending on how frquent you use..
HOpe this helps
Oct 30, 2009 | Dell Inspiron 1525 Laptop
Inspiron 1300 battery
If you have replaced the battery with a NEW one and it doesn't charge, then you either have an issue with the AC adapter (If the sensing pin is bent or broken in the barrel of the connector, the battery will not charge) or the charger curcuit of the motherboard. If the issue occurs on a different AC adapter, then FLash the BIOS to current version. If battery still doesn't charge, then replace the motherboard
Jun 24, 2009 | Dell Inspiron 1300 Notebook
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
New battery wont charge
I had the same problem. First, I ordered a non-Dell battery online but battery would not hold charge either - had to send battery back twice but new battery wouldn't work either time. Finally, I resigned myself to ordering one from Dell directly and it's working fine now - so my advice is to bite the bullet and pay more for Dell battery.
Apr 15, 2009 | Dell Inspiron 1300 Notebook
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
Battery and or charger
Try removing the battery and see if the laptop works with the AC adaptor. If not either the AC adaptor is bad or the motherboard is defective.
If your battery LED flashes (yellow or Amber) or is solid Yellow or Amber color, this usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
As for the error message “failed DST short test 1000-0146”, this is flagging an error on your hard disk drive. This could be caused by a bad hard drive or just needs to be reformatted.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Inspiron 9300 Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
Dell Inspiron 1300 Notebook Logo
380 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
