Question about Electrical Supplies
My Gen Pro II generator is not putting out any 110 or 220 power
3 Suggested Answers
sal_kh_sab
  • 98 Answers
SOURCE: 5000w gen. no powe out put
when engine runs but no power is produced ...there are three things you need to check:
1- brushes may be shattered.(open the generating unit cover(from the stator and rotor side) and you'll find it..if it is shattered..then replace it.
2- breaker...to test this disfunction...connect the two wires(the one going to it and the one coming out of it) together and try again...if it generated power..then the breaker is out of order...either replace it...or keep it connected directly (DON'T leave any naked wires)
3- AVR open the generatng unit cove again.you'll find the AVR (screwed to the rotor holder) here is a picture of an AVR:93c8b52.jpg if it is burnt out...replace it..
IF you tried the 3 things i wrote and none of them worked, then you have a problem with the stator or the rotor...but that is very rare to happen...it's probably one of the three///..
Posted on Oct 26, 2009
  • 512 Answers
SOURCE: My generator will start but is not getting enough
Just what kind of appliances are you trying to run with that little generator?
Check the wattage each appliance is rated for, check how many other things you might be powering, add it all up and that is what you will have to power it with, plus a few thousand watts for a cushion. Most likely you have exceeded the output of your generator. Turn off everything and then see what it can power simultaneously.
Posted on Oct 02, 2012
Rv Motorhome Onan Emerald III Runs fine no power out put
There is a breaker at the gen. usually near the start switch. When off no power from gen. to house.
Oct 31, 2016 | Electrical Supplies
My generator will start but is not getting enough power to turn on appliances in the house what could be the problem? Its a coleman pro gen 5000 with a 5 gallon gas tank.
Sep 30, 2012 | Electrical Supplies
I've got a Gen Pro 9000 watt gen with a 16 hp Vanguard will not charge the battery
this may be due to a bad voltage rectifier it should look like a small box with wires coming out of it. Disconnect and have it checked
Dec 09, 2009 | Electrical Supplies
No power to the panel of my generator
first volts come in out put wires or not may be its pannel problem
Sep 04, 2009 | Briggs & Stratton 15,000 Watt Home Standby...
Briggs elite 5500 model 01654 putting out too much power at outle
butterfly shaft on engine siezed causing irregular high idle. high idle causes over powering surge from stator/rectifier assy. idle sppeds must be within gen specs for accurate output levels.
Jan 16, 2009 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Electrical Supplies Logo
16 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
