Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Tank is full
Ink tank is full
  • Canon Expert
  • 398 Answers
There is a full waste ink tank, (cup) empty it (messy) -Carl
Posted on Jun 23, 2009
Ink full tank
cannot replace ink full tank if the cartridge had coagulated ink in it . better keep it for some times on mild hot water and replace it after wiping the water it would do the trick. don't forget to do so before refilling it to have ink full tank.
May 13, 2011 | Canon PIXMA iP1800 Printer
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Full tank so what can i do
> full tank, so what can I do?
Are you saying that the ink-cartridges in your printer are full, and that your ink-jet printer is still not printing?
If so, use the software that came with the printer, to run a "print-head-cleaning" cycle,
to "unclog" the ink-jets that pull ink from the tank and shoot the ink onto the paper.
Nov 21, 2010 | Computers & Internet
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer message, ''out of ink'', ink tank half full.
Nope....the sensor looks at the reservoir. replace your ink
Mar 25, 2009 | Canon Office Equipment & Supplies
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Pixma Ip90v waste ink tank full
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Dec 16, 2008 | Canon PIXMA iP90v Printer
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Aug 03, 2007 | Cannon MULTIPASS C530 Printer
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
87 people viewed this question
old marine
old marine
