Question about KitchenAid KSM103 Professional 5 Series Stand Mixer
My mixer is 'shocking' me?
I guess it technically isn't 'shocking' me, but when I plug it in, it hurts me when I touch it. It's really the only way to explain it. I'm pretty sure the mixer still works, but I am afraid to use it. How do I fix this issue, if it can be fixed at all?
  • KitchenAid Master
  • 16,026 Answers
Look at the plug and see if the spades are the same size, One should be bigger than the other one. The problem could be the outlet that you are using too. If one spade is big then that would mostly rule out a short to the case of the mixer BUT if it was taken apart or serviced and wired wrong then the HOT connection is causing a short to the case. IF the outlet is wired wrong then the power is getting to the case when it should not be. Also the kitchen should be wired so that all the outlets are GFI and should not be shocking you.
Posted on May 13, 2014
  • Ashley McDonald
    Ashley McDonald May 19, 2014
    My parents recently had part of the kitchen remodeled, including some rewiring. So I pulgged the mixer into one of the older outlets and it seems to be working properly. I wouldn't have thought to try another outlet, but that seems to have solved the problem. Thank you for your help.
Kenwood kmix shocked me when i touched the body ...
Stop using it. If the insulation on the power cord is cracked, cut, or bare, you are getting a short from a wire being exposed to the mixers body. This could cause a Fire and/or injure you directly. The source needs to found by a technician and repaired.
Mar 24, 2014 | Food Mixers
KitchenAid Classic Plus Shocking
Sounds like there is a pinch hot wire inside or a wire inside that has worn and is now bare. Disassemble if you are comfortable doing so and check the wiring inside. Also check you power point to make sure that the ground is truely ground. In some countries ground is common and not bound at the meter box which can allow power to feed back to common.
Jan 11, 2014 | KitchenAid 32685 Mixer
Getting an electrical shock from the outside of my Kitchen Aid power stand up mixer. No visible break in cord.
But!!!! there could be a break in the grounding wire inside the back of the mixer motor head, it is easy to check. face the rear of the mixer and look at the top you will see a small screw, remove it and gently lift the rear cover up and out muck more up than out (you could break off the mounting ears on the bottom of the rear cover) then look at the plug wires, white and black wires should be attached by clips to speed control switch the green grounding wire should be attached to the mixer frame with a screw, if it has come off then put it back on, the screw should have fallen out when the rear cover was taken off if the screw has come out, it may just be loose also so use a phillips head screw to tighten down. please let us know if this helped or you need more help there may be a more serious electrical problem that needs to be dealt with.
Feb 18, 2013 | KitchenAid Professional 600 Series 6-Quart...
Mixer stopped turning while kneading dough. My guess is it blew a fuse?
Yes could be ..check the fuse in the plug first , then see if a Thermal cut off has taken place if so reset this ,if still dead then chance is the motor has gone , which is quite expensive to fix, you may be better with new machine....Good luck...
Feb 19, 2011 | Jenn-Air Attrezzi JSM900 Stand Mixer
I have a Hobart KitchenAid Mixer Model K45SS and it runs fast on low (Surges speeds up and down)what is causing this problem
Hello Mayfix,
The problem with your mixer is the speed control switch, this switch is located at the back of the unit. It is usually black and has all of the wires coming into it, the Item # 1394070 and cost $27.95 it can be located at RepairClinic.com he is a link
http://www.repairclinic.com/Kitchenaid-Switch-Parts?z=100&gclid=CKSD5NriuKcCFUVqKgodIE2b_g
You will have to adjust after you install you will adjust the two screws at the top of the switch while the machine is running inorder to make sure that you are getting all the speeds. Be careful as there is a possibility of electrical shock if you touch the wronge thing.
Thank you for using FixYa.
Jul 04, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer ksm160 stop working after a flash appear  in the rear of motor
We have a 10 month old KSM150 and the same thing happened. I called to have it fixed under warranty and their 'Hassle Free' replacement warranty is anything but! The spped controll leaver slides the electrical switch back and forth at the very back of the unit. Looks like there are 2 small metal spring connections that maintain contact when things are working properly. There is one screw at the top of the small dome at the back; removing this screw gives you access to this. I bet you will find that these 'spring connections' have come loose from the vibrations and are causing a short with the exposed electrical terminals. As far as I am concerned that is a design flaw and poses a serious danger of eletric shock or fire and KitchenAid shoud fess up before someone with the wrong breaker in their home gets hurt. I am mad as hell. findsh@hotmail.com
May 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen Aid switching from mixer mode to grinder
There is no switch. When you have the accesory in the front, the beater section still moves. I suggest that you remove the beater so that there is less possibility for someone to get hurt.
Nov 07, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Hobart 20 QT. mixer (HL 200) will not operate on a GFCI receptacle.
you need to replace the gfci,the older gfci's interpret these frequencies as a shock hazard and shut off power to the circuit.you can buy @hobart, part#913053, that should solve the trip problem. dont forget to vote thanks monomoy
Apr 05, 2008 | Food Mixers
N-50's need restoration
im a hobart service tech and service these mixers alot.the usual suspect problems is the tumbler assembly.service manuals from hobart---good luck they dont release them.i can help you out,
Jan 18, 2008 | Hobart N50 Stand Mixer
Open Questions:
KitchenAid KSM103 Professional 5 Series Stand Mixer Logo
82 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
