Question about Maytag Dryers
Maytag model# LDE482 electric dryer won't blow hot air
Hi. My Maytag model# LDE482 electric dryer won't blow hot air. The other night, my wife put in clothes at 9:00P.M, and the next morning, the dryer was still running. It looks like the timer on the regular fabrics section died. The timer still works on the timed dry and permanent press selections(I can hear the timer clicking). Now the dryer won't dry anything, it turns on and the motor sounds ok, there are no blockages in the exhaust tube???
    Top Expert:
  • Maytag Master
  • 81,423 Answers
Either the control panel is defective or the dryer heating element is defective.
Posted on Jun 28, 2017
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
Illeagle
  • 525 Answers
SOURCE: Maytag electric dryer model # MDE2500AYW
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance:
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
jonniewalker
  • 1031 Answers
SOURCE: My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Posted on Feb 21, 2009
  • 686 Answers
SOURCE: Maytag Gas Dryer MDG308DAWW doesn't blow hot air, no clicks heard
Look at the bottom of your front panel and see if you can see a screw on either side about 2-3 inches from the very bottom edge of the front panel. If so take them out and pull the bottom away far enough to disengage the top of the front panel from the top panel. If this works for ya. then now you have it openened, if not repost me.
Posted on Apr 13, 2009
SOURCE: Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Posted on Jun 23, 2009
Maytag quiet series 300 manual
pf is power failure because you unplugged it,is it gas or electric,that could be anything,you need to open the door,look around the opening and find the model number and send it,if it is gas you could have bad gas coils located on the gas valve,they will work for the first 15 to 20 minutes and when they heat up they will fail only if they're going bad so the clothes will feel warm but not dry,also you still could have a block in the vent line or in the duct where the lint filter slides into,there's a blower wheel in there that blows the air around,remember all a dryer does is move hot air around to dry the clothes,the easiest way to check the line is to remove it from the back and run it,but first clean out where the lint filter slides into
Oct 01, 2017 | Dryers
Maytag neptune dryer doesnt heat
On the housing the element mounts in is a couple of safetys The smaller one is rated for 300f and the bigger one is rated for 250f. If the smaller one is tripped obviously you replace them both, making sure the vent to outside is clear. Them fuses blow or trip because of air restrictions.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Maytag Dryers
My problem is with my Maytag-Legacy Series electric clothes dryer. My wife says it does not cool off the clothes at the end of the cycle, and thus leaves them wrinkled, so she needs to iron them. What...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 28, 2011 | Maytag Dryers
Not getting hot air
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 10, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Kenmore Dryer doesn't shut off and doesnt' get hot
heatman101
Apr 14, 2010 | Kenmore 73952 Gas Dryer
Electric Maytag Neptune Dryer not heating up.
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
Jul 21, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag electric dryer model mde308dayw not heeting up
CHECK YOUR WALL VENT AND DRYER VENT AND MAKE SURE THEY ARE CLEAR,ALOT OF THE TIME IF BLOCK THEY HOLD THE DAMP HOT AIR IN THE DRYER AND WILL TAKE FOREVER TO DRY,IF NOT THAT IT CAN ONLY BE YOUR HEATER BOX OR HEATER BOX FUSE,IF YOU HAVE A METER YOU CAN CHECK BOTH,LET ME KNOW-MIKE
Dec 06, 2008 | Dryers
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
362 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
