Ibm selectric ii why does it keep typing when turned on and no keys are hit?
  • Dick O Reilly May 15, 2014
    Usually the trip mech. is gummy and needs lubed WD40 works well.
  • 453 Answers
Most likely needs cleaning
Posted on Oct 25, 2014
JayBlair
  • 328 Answers
SOURCE: return key is stuck
Need more info. Many different possibilities.
Posted on Aug 12, 2008
teomie
SOURCE: IBM Selectric II
Can I clean and lubricate it myself or do I have to pay someone
Posted on Sep 25, 2008
  • 4 Answers
SOURCE: Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
Posted on Apr 19, 2009
  • 3594 Answers
SOURCE: IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
Posted on May 28, 2009
komguy
  • 2306 Answers
SOURCE: My IBM Selectric II types the wrong letters.
Sounds like the cable might have slipped off the pulley, with the cover off, check all cables to the carriage assy. You need a tool like a spring hook to gently slide the cable back on to the pulley.
Posted on Jul 24, 2009
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
I have a couple of IBM Selectric II Typewriters and over the last few months both just quit as if they are getting no power. One started working again but then quit again..any ideas on how to fix. Also had...
Most selectrics at this time are suffering from many gummy parts.
All of these problems are probably repairable with a good chemical cleaning and lube.
DickyO
Dec 11, 2009 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
I have an IBM Selectric II. It types but does
The tab tensioner on the R. side is probably broken, not a bad job but you have to know how.
DickyO
Sep 12, 2009 | IBM Office Equipment & Supplies
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
DickyO
Sep 08, 2009 | IBM Office Equipment & Supplies
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM CORRECTING SELECTRIC II TYPEWRITER
Is the key stuck in the down position? If you pull the key off you should see a spring underneath. Maybe out of position or damaged.
Aug 10, 2008 | IBM 3500 Typewriter
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
May 15, 2008 | IBM Wheelwriter 30 Typewriter
jasbo
jasbo
