Question about Canon SmartBase MP730 All-In-One InkJet Printer
Mp730 won't print color
Canon mp730 won't print color. have added 2 new print heads, problem started when I installed the first new printhead. new ink tanks used both times. made no difference. black prints but no color
    Problem Solver:
  • 18 Answers
I would test using color copy, and make sure it does not work in color there. You are using a new print head and new cartridges that are full and seal removed, so everything should work. Well your printer is getting old, and those contacts on the carriage may be tarnished a bit. Before you give up, remove the print head, and with a knife scrape those flexible pins a couple of times, one row at a time, and put everything back, lever down, cartridges in, and see what happens.
Posted on Mar 23, 2010
  • 4,041 Answers
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you will need to clean out the waste ink it inside the printer all got to be open up to do this.
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 26, 2010
2 Suggested Answers
  • 1218 Answers
SOURCE: Canon MultiPass MP730 purchased 2004 NOT
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Posted on Dec 02, 2010
Canon MultiPass MP730 purchased 2004 NOT Printing Black INK- did: new canon ink tank inserted (never used refills) ran: printhead maintenance mannually cleaned print head w/ rubbing...
Dec 02, 2010 | Canon Office Equipment & Supplies
Canon Multipass MP730...placed new ink cartridge in twice now...nothing be printed...what could the problem be?
For me, there can be 3 problems, and I will do what I do in order.
1. The print head may be clogged. To unclog it, you have to remove the 4 cartridges, remove the print head (lever up, and remove the printhead), run those silvery things under a luke warm tap and low flow and pressure for about 5 minutes or until no ink drips out, and dont aim for those silvery things, do not touch the contacts on the back. Install the printhead, cartidges, lever down and go for it.
2. Well still no results... Get the printhead out of there again as your machine is getting old and tarnished. Get a sharp knife. Stroke down on those contact things downward only with your knife, a couple of columns at a time, couple of strokes per column. Put everything back, lever down, and go for it.
3. A new print head $50. Sounds a lot, but the last cartridges were $1.69 a pop. These cartidges last quite some time, as long as you fire something through the printer each week. This has to be the most economical bubble jet printer in the world. I have 3 of them.
Jun 16, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
I have a Canon i9900 printer. I have used the daylights out of it. Can printers start to print blurry if they are wearing out? My prints look fine at 100% on the monitor, and when I print the picture it...
Problem : Ink does not eject properly or Printing is blurred or Colors are Wrong or White streaks appear.
Cause 1 : Ink tank is not seated properly or the ink tank is empty.
Action : Check that the ink tanks are firmly seated in the print head and reseat them, if necessary.
Check that the correct ink tanks are installed and that they are in correct order.
Check to see if all the orange tape has been peeled off. If a part of the orange tape remains, remove it thoroughly.
If an ink tank is empty, replace the ink tank.
Cause 2 : Print head is misaligned.
Action : Align the Print head.
Cause 3 : Print Head nozzles are clogged.
Action Print the nozzle check pattern to check for uneven ink output.
When specific color is missing from the nozzle check pattern, clean the print head.
Cause 4 : paper is not loaded with the print side up.
Action : Checl that your paper is loaded with the correct print side facing up.
Note: Follow the instructions packaged with your specialty media for loading and handling.
Cause 5 : Incorrect paper type.
Action : Windows : On the Main tab of the printer driver, confirm that the selected Media Type matches the paper loaded.
Mac : In the Print dialog box of the printer driver, select Quality &
Media from the popup menu, and then confirm that the selected Media Type matches the paper loaded.
Cause 6 : Glossy photo paper other than the Canon specialty media is used.
Action : Select Other Photo Paper from Media Type. It may resolve the problem. Load one sheet at a time and remove each sheet as soon as it is printed.
Hope this helps.
Thanks
Have a good day.
Dec 04, 2009 | Canon i9900 InkJet Photo Printer
How do i replace the printhead
The Print head is sitting in a cradle. So do not confuse the cradle with actual print head. The cradle is the one that slides left and right on the metallic rod. Do NOT try to remove the cradle.
Make sure to use genuine Canon ink cartidges.
1) Unplug the power to the printer. Remove the USB printer cable.
2) Lift open the top cover by depressing the round button on the right side of the printer; exposing the printer ink cartridges.
3)Lift the grey lever on top of the cartridges. This dis-engages the printhead electrical connections. Remove all the 4 ink cartridges from the printhead. From the cradle hold the printhead from the top and lift the printhead by tilting it toward you. Make sure not to touch the electrical contacts in the back printhead.
4) Take a small plastic bowl and fill it with 1/4 inch or less with Rubbing Alcohol(70% Isopropyl Alcohol). Dip the bottom of the printhead in the alcohol. Soak printhead in the alcohol and shake it lightly so the dried ink clogging the printhead can come loose. Us paper towels to soak excess alcohol from the bottom of the printhead. Make sure not to damage the printheads.
5) Pour some alcohol from the top of the each inlet of the ink cartridge seat and again soak up any excess alcohol with paper towel. Let the print head dry up little.
6) Put the printhead back in the cradle and insert back the ink cartridges in their right seat. Lower the grey lever back into its position so the electrical contacts are made on the printhead.
7) Plug the power and USB port.
8) Print a picture or diagram with color in draft mode. You might have to do this couple of times, so that the inks starts flowing from the ink cartridge through the print head. Then print the same in high quality. If the heads are unclogged your printer should work as new.
Just one bit of advice: you may wonder if you've got the position right because the grey lever may not seem to be able to engage - it will, but needs a fairly strong push to click into position again.
Oct 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Mp730 message wrong cartridge??? I did install a new ink cartridge, no help so I cleaned and reinstalled the print head after shutting it down for 30 mininutes no help. Still geting the same message....
That message means that you need a new printhead, the holder where your inks go. the part number is QY6-0064-000 around $40.00. easy to change yourself, instructions are included.
Jun 29, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
Apr 25, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP390 Printing no magenta & now nothing!
Hey Everyone!
I have an MP390 that had a similar problem over a year ago. There is a very simple fix that worked for me, and I'm pretty sure that it will work for you too. :^)
Outline:
Open the printer as though you were going to replace the ink tanks. Once opened, with the print head centered, open the latch and remove all of the ink tanks. Gently remove the print head (it should come right out, even easier than the ink cartridges). Take a paper towel, wet it with warm water, and then gently clean the bottom part of the print head. The bottom part is the part that will have an orange ribbon running to four metal openings that look like tiny nozzles. After wiping away all of the built-up gunk (on mine there was a thick sludge), grab a new and wet paper towel, and lightly press it against the nozzles. This should start sucking ink through the print head, and you will begin to see four distinct colors (CMYK) bleeding into the towel. Once done, lightly dry the print head off (make sure that there are no loose water droplets) and then reassemble everything. Print a test page and everything should work. If it doesn't change the ink tanks just to be sure.
Fortunately for you, Canon has made the print head on the MP390 very easy to service/remove, so cleaning is a snap.
Steps:
  1. Turn Printer On
  2. Open Printer As If To Change Ink Tanks
  3. Release Ink Tank Latch
  4. Remove Ink Tanks
  5. Remove Print Head (Black Plastic Assembly In Which Ink Tanks Rest)
  6. Use Wet Paper Towel (With Warm Water) To Clean Tank/Nozzle
  7. Dry Excess Water
  8. Reassemble
  9. Close Printer
  10. Print Test Page
Good luck!!!
Jul 28, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Canon SmartBase MP730 All-In-One InkJet Printer Logo
128 people viewed this question
old marine
old marine
