Question about V-Moda Audio Players & Recorders
V-Moda broken screws
The screws connecting the ear cup to the hinge on the headband broke in half, and are stuck in the hinges on the ear cup on one end. I've tried many different epoxies, krazy glue, soldering but i cant get them to reattach.
  • 279 Answers
SOURCE: broken screen hinge/collar
You can purchase replacement hinges and hinge covers here: http://www.mundocorp.com/m275.html They may be a bit of work to replace. But short of replacing the hinge assembly, it doesn't sound like that is going to move.
Posted on Aug 28, 2007
SOURCE: nintendo ds broken hinge
this is a cheap solution too. you can buy a nerf DS lite case. Since the systes is inserted there, it will hold off. that's how we fix it in the store when a customer come with the problem and needs a cheap solution. Under $15 and you don't have to open the system to replace it.
Posted on Sep 11, 2008
SOURCE: Need instructions for replacement of headband and ear cushions.
It should be easy - I just eased mine out by pulling on the top and bottom parts of the headphone cushion/pad.
Hope that helps
Posted on Nov 27, 2008
  • 489 Answers
SOURCE: Warranty
most of electronic products have not warranty if they have damage. i mean water, break. your seller is right.
Posted on May 28, 2009
  • 8 Answers
SOURCE: Broken (cracked) right Hinge on HP nc 4000 and Dell D600 Laptops
You can get replacement parts for this laptop, however it can get expensive. At the end of the day, you can use a super glue that is safe to use around electrical parts, but you might be better off just using an external monitor if you don't need to carry your laptop around.
Posted on Jun 01, 2009
Help. Porsches toilet. Trying to adjust toilet seat. The hinge cover is fixed so hard that it came off with the screws. Cannot access the screws as hinge cover is stuck fast. How can I remove it?
You can try using a putty knife to pry up the edge of the covers. The hardware often is less-than-durable plastic so the end result may be destruction.
Jun 06, 2016 | Home
Over time the hinge on my Dell 8100 Inspiron gradually froze up and broke the aluminum block in the middle of the the screw that held it in place, ie. half the threads on each side of the broken piece. ...
Very common break, best is to have service performed by some one that knows what they are doing, machine has to be taken apart and new base installed, sometimes if slight break they can be epoxy. but usually needs new base andor hinges.
Nov 04, 2017 | Dell Inspiron 8100 Notebook
Broke the hinge on my Samsung Alias 2. Need to repair it - have the parts! I had earlier broken my LCD and took the ****** apart, and put a new LCD in. Works fine, but not all of the original screws and...
The spring goes under the little plate that is held in by two tiny screws. Its visible when the phone is open vertically with the plastic cap removed from the hinge. Hope this helps. I took my hinge apart after I dropped it and the top half came off... now it's just holding by the ribbon so I'm going to order a new hinge. Verizon is completely useless. They don't want to even know about you if you're phone isn't under warranty and I have 11 months till an upgrade...
Jun 29, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How do I remove outer door hinge housing to replace with new one?
there are four screws holding the hinge on to the machine. two are visible in the hinge from the front but there are two inside the machine on the left side .turn off the power and water supplies drag the machine out from its place tilt machine back to allow a gap between the drum and cabinet then using a star shaped driver also called a Torx driver remove the two screw from the hinge and remove it.when refitting a magnetic driver is a great help to prevent dropping the screws into the machine a torch is advisable to see what you are doing I hope this helps
Sep 19, 2009 | Dyson Memory CRO1 Front Load Washer
Hinges for top cover for HP officejet 6210- Q5820A
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
How do you disassembly right side headset to fix faulty connection
The headphone unit is sealed and cannot be accessed via the padded ear pads. You have to prise open the outer headphone cover which breaks off 4 internal attachment points (which can be re glued for re assembly). Be careful on the Left hearphone as it contains a complex electronic circuit board.
Aug 01, 2009 | Jabra C820s Headphones
Lid will not close. Jams half way down
is there any build up any where aound the hinge? Rub a bit of butter on hinge then move lid up & down. this is kind of like oiling something but your using butter or margerine. I do this on the hinges of my doors when they start to squeek.
Jun 10, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Whirlpool Ultimate Care II, model LSQ9010KQ0
lid switch lift lid and listen for click when lid shuts.. believe switch on rear left just behind lid hinge or on older models right side about half way opening (ck for boken lever or screw holes)also hinge may not be fully contacting switch ckd hinge screws just in case first if too much play in hinge will fail to contact switch..switch may be acessed by removing screws in bottom rear corners on back of console and lifting console
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
8820DN hinge problem
To answer Meyerson's questions:
My symptoms did not include papers jamming in the ADF -- in fact, the ADF didn't work at all due to the broken left hinge.  :(  Also, I don't recall having any unusual problems with the ADF jamming frequently before the hinge broke to the point where the ADF didn't work at all.
I obtained the replacement ADF left hinge assembly by searching online for a parts dealer.  I believe I ended up ordering the part from Precision Roller.
I hope this helps,
-Barb
Apr 01, 2008 | Brother MFC 8820D All-In-One Laser Printer
190 people viewed this question
Top V-Moda Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
john h
Are you a V-Moda Audio Player and Recorder Expert? Answer questions, earn points and help others
