Question about Coffee Makers & Espresso Machines
Astoria sae 2n . the lights stay on. They do not
Astoria sae 2n . the lights stay on. They do not flash. Nothing comes out of the heads but water did come out of spouts that are located directly behind panels. There seems to be one for each espresso head and they put directly into drain pan. The water spout in center dues nothing. Steam spickets steam to work but stay of with more water than anything before it seems to steam. If I press any of the buttons, nothing comes out at all. What could be the problem?
    Genius:
  • 1,114 Answers
Has the machine been cleaned / descaled? Coffee machines become clogged with mineral scale deposits from the water. Some folks use citric acid , about two tablespoons /qt of water, and some folks use white vinegar, 1/2 & 1/2. Place the solution in the machine as if you were making coffee. It may take a few cleanings if there is a lot of deposits. After cleaning dissolve two tbsp of baking soda in a quart of water and run through machine to neutralize the acid.
Posted on May 13, 2014
kaldiDOTcom
  • 22 Answers
SOURCE: hot water no steam low psi
Boiler pressure gauge should be showing in the green zone which should get you 195+ degrees.
Posted on Nov 18, 2008
SOURCE: Astoria SAE-2
yes i found ur probelm . this might happen because of coffee deposites in the porta filter.
remove the screens with the help of the screw driver and wash it throughly .
then fix it again .
if still it is not working then , call me i will help u out .
ROhit PAtil
india
9766678617
Posted on Dec 30, 2008
EsWorld
  • 1618 Answers
SOURCE: we have an older faema due machine. Currently the
The tip of the steamwand is clogged or the fitting where it connects to the boiler is blocked with carbon.
Posted on Jun 20, 2009
SOURCE: Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Posted on Aug 12, 2009
mrpsespresso
  • 16 Answers
SOURCE: Pasquini Livia 90 - No water from the group head
The problem could be calcium built up blocking the jet and stopping the flow of water through your 3 way solenoid valve.
Otherwise the 3 way solenoid has stopped working. The 3 way valve part #91004 is $105 + shipping.
If you capable of removing the top and 3 body side of the machine, you can contact me and I can walk you through diagnosing if this is the problem with the jet or the valve. Before you call, make sure you have a philips screwdriver, 14 and 15mm open ended wrench or crescent wrench, flashlight, and paper clip.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Posted on Nov 15, 2009
Astoria Divina SAE/2N 2 heads. What would make the spout in between the heads be only cold water and the water level gauge shows all the way at the top of the glass?
If by spout you mean tea valve, it could be that the economizer mixing solenoid valve is set to deliver more cold water when mixing. As for the level the silver probe on boiler.
Oct 08, 2015 | Astoria Coffee Makers & Espresso Machines
Astoria blinking light
If all the lights are blinking the machine is not getting water fast enough.
Jan 12, 2013 | Astoria Argenta SAE-2 Espresso Machine
Blinking lights in Astoria sae
Water is not flowing through the flowmeters. It could be a blockage in the line or the wheel is damaged or the flowmeter head is damaged. But the blinking lights indicate a water flow problem.
Oct 27, 2011 | Astoria Argenta SAE-2 Espresso Machine
We have an astoria model SAE.2 for some reasen the machine has gone very quiet and appears to be strugling when re charging after each use
It sounds like the water pump is not doing its thing or the machine cannot get water, either blocked filter or water line.
Jan 03, 2011 | Astoria Divina SAE-1 Espresso Machine
Astoria sae 2n machine tank is full but not heating, any ideas
Check to see if your machine has a reset thermostat on the left side of the boiler, on new models it is located on the top, second some machines have a 2 position switch make sure it is on 2.
Aug 20, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
I have bought a used Astoria sae Espresso Machine and I need to know how to clean it - can you help?
You'll want to back flush the machine with espresso machine cleaning powder:
http://www.kaldi.com/cafe_supplies.htm and regenerate the water softener regularly.
May 21, 2010 | Astoria Argenta SAE-2 Espresso Machine
Boiler has quit working
Check to make sure that there is water in the boiler by either checking the sight glass then rocking the machine to see if the water level bobs up and down, then check the thermal reset switch on the left side of the machine above the element. Make sure there is water in the boiler before pressing reset and turning machine to number 2. After machine heats up make sure pressure does not go past 1.5 bars on the gauge. If it does then the p.stat needs to be replaced.
Nov 01, 2009 | Astoria Argenta SAE-2 Espresso Machine
Water still following from the right dispence
The coffee solenoid valve which is located on the coffee group is having a dirt which is keeping it always open and the water is direct with the mains on this valve so you have continuing water out from the group head. You have to close the water mains valve to stop this. Remove valve and clean it. Dry coffee on the valve can cause also the same problem so clean the valve.
Please remebr to vote for this answer thanks
Oct 25, 2009 | Astoria Argenta SAE-2 Espresso Machine
Hot water no steam low psi
Nov 17, 2008 | Astoria Argenta SAE-2 Espresso Machine
Coffee Makers & Espresso Machines Logo
55 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
